presta valve woes
[Closed] presta valve woes
 rock
[#936401]
Hi,
I've got one of those lezyne micro pumps, with the screw on hose thingy. I was using it to pump up a road tube the other day, and when I went to unscrew it it unscrewed the whole top section of the valve, letting all the air out. I tried a few more times, but every time the valve came apart, letting all the air out.
It seems there's a problem with the rubber ring thing on the hose gripping on the valve, and so unscrewing the whole thing when the hose is removed.
Anyone got any ideas how I can stop this happening again? Is it just a matter of a bit of loctite in the valve?
Posted : 09/10/2009 10:48 am
Presta = shite
HTH
Posted : 09/10/2009 10:50 am
Stick some lube on the rubber ring
loctite or PTFE tape on the valve
actually, I don't understand - you have to unscrew the valve thingy to get any air IN. If you undo it as far as it'll go it can't undo any more...
Posted : 09/10/2009 10:51 am
Screw on adaptors for presta? Never seen them.
Posted : 09/10/2009 10:52 am
some presta valves have removeable cores, i guess this is the bit that is coming out
Posted : 09/10/2009 10:53 am
the whole valve core is coming out is my guess.
bit of lube ont he rubber int he pump head will help plus gettign a proper valve core tool and making sure it's done up tight.
 rock
yep that's right - it's a two-piece valve, and the hole core is coming out. Seems like a crazy design.
I'll try the lube trick. Unfortunately I didn't have any lube when this happened yesterday. Puncture 10 miles from home. Luckily a passing numpty lent me his plastic mt zefal pump, which did the job.
Posted : 09/10/2009 10:56 am
it allows you to replace the inherently weak valve core when you inevitably snap it
also allows you to put in sealant
Posted : 09/10/2009 10:57 am
a numpty? ooh get u 😯
Posted : 09/10/2009 11:13 am
I'm with SFB on this.
Drill the rims if necessary and fit something that won't fall apart - Schraeder valves!
Posted : 09/10/2009 11:18 am
 rock
prestas are fine on my mtb, it's just on the road bike. Besides, I'm not sure a schraeder would cope with 120psi
Posted : 09/10/2009 11:22 am
I've never ever run Schraeder valves. Seem odd technology to me. Also I've never ever had problems with Presta valves; they are much easier to inflate even apart from OP who seems to be doing something odd.
Posted : 09/10/2009 11:26 am
lucky you met the numpty with a working pump, oh! hang on 🙄
Posted : 09/10/2009 11:43 am
I've never ever run Schraeder valves... they are much easier to inflate
if you've never used the others, how would you know ? [b]Much [/b]easier ? Easier how ? Attach pump to valve. Pump pump pump pump pump pump pump pump stop. Except I've found with Presta most of the air comes out sideways instead of going into the valve 🙁
Posted : 09/10/2009 11:45 am
I have had multiple presta valve cores snap off on me - maybe I am cack-handed but it's pretty annoying.
 rock
for the avoidance of doubt, numpty wasn't meant in a derogatory sense. It was just shorthand for saying he was riding a badly maintained bike, wearing tracksuit trousers and a yellow tabard.
He was a thoroughly charming chap, and saved me from a very long walk.
Posted : 09/10/2009 11:46 am
I've had quite a few Presta tubes wasted by the valve tearing away at the join with the rubber. Never had any similar problems with schraeder.
And don't be daft, it is definitely easier to inflate schraeder valves!
Posted : 09/10/2009 11:48 am
IF you can get it to stay on. IF you can get that sticky out bit to push the valve in. IF you can then keep the air going in instead of coming out sideways. IF you can release the adaptor without letting all the air out. Scraeder suck.
funny, till the penultimate word I thought you were describing Presta :o)
Posted : 09/10/2009 11:51 am
Really, unless you're a complete numpty or have tried using a hammer instead of a pump to inflate presta tubes, it's virtually impossible to knack them.
apparently lezyme are bringing out a new slip chuck to resolve this problem which can be retrofitted to its "older pumps"
Posted : 09/10/2009 11:52 am
Shraeder's a bit special needs imo.
I kinda of assume that they're for people who need a torque wrench to fit a water bottle cage 🙂
Fair enough, but 'odd technology'? Eh?
Valve, lets air in, keeps air in. What's odd about that? 😕
So did I!
Posted : 09/10/2009 11:54 am
