Press fit bottom br...
[Closed] Press fit bottom bracket confused.. Com help please ๐Ÿ™‚
Googling is confusing me so hopefully one of you can help!
I am used to octalink, square taper, ht2 not these new fangled press fit jobbies!
So bearings rumbly and making noise. Could someone please point me to a replacement that will fit!
Cups marked shimano
Cups Looks to be around 41mm OD
The crank shaft is 24mm
The width between cups is 91 mm ish.
The spec sheet says the frame takes a pf92 bottom bracket.
It's a trek stache 5 (29 plus)
Seems to be so many options!
Thanks so much for any pointers ๐Ÿ™‚
Posted : 24/04/2016 4:36 pm
Sorry.... I think I have found the correct one if anyone can confirm! Only thing not mentioned is 24mm axle size.
Is it worth getting the sm-bb92 (xtr) version over this? Better sealed?
Thanks all!
Posted : 24/04/2016 4:53 pm
Oops link would help.
http://www.chainreactioncycles.com/mobile/shimano-bb71-mtb-press-fit-bottom-bracket/rp-prod61801?gs=1&gclid=CjwKEAjw3fG4BRDsn9GAv7T2zEkSJACNJdjghKpO2WlIsg1a8Gzof1PN7UXk3Aa6Qi4-KHX9zSRs4RoC35vw_wcB&gclsrc=aw.ds
And a pic
[URL= http://i1324.photobucket.com/albums/u603/davecorleoni/Mobile%20Uploads/20160424_155528_zpspx18xcj6.jp g" target="_blank">http://i1324.photobucket.com/albums/u603/davecorleoni/Mobile%20Uploads/20160424_155528_zpspx18xcj6.jp g"/> [/IMG][/URL]
Posted : 24/04/2016 4:54 pm
Looks like a race face crank?
Probably a shimano pf92 MTB bracket then
Posted : 24/04/2016 6:47 pm
Ha ta ordered one. Funny this place.... Post about a car, a fence, a position in IT, management advice...i.e anything not about actual bikes and you get hundreds of replies! Post about bikes and tumbleweed... Apart from you esher shore... You win the Internet today. Smiley face emoticon
Posted : 24/04/2016 7:31 pm
