Prep M and Grease G...
[Closed] Prep M and Grease Gun
Need to replace bushings etc on my suss and recommended to use Manitou Prep M.
I can find the grease but no-one stocks or has one in stock the grease gun (head) that fits....at least not one that i can find!
Is there an alternative to this grease and a gun that will fit the micro zerks grease ports
Its an 05 Turner 5 spot (2nd hand so never done it before)
If anyone knows a place thats stocks it or has used something that is just as good and easier to find that would most appreciated!
Jon
Posted : 22/05/2009 10:09 am
[url= http://www.billys.co.uk/english/group.php?prod=2dul-mininoz ][/url]
I bought one of these for my Banshee Rune and it works great, together with some Finish Line Premium grease.
Posted : 22/05/2009 10:25 am
http://www.chainreactioncycles.com/Models.aspx?ModelID=35285
One of these fitted on my tube of Prep M.
Have 2, also fitted on Shimano grease tube, finishline, currently attached to Rock n Roll tube of grease.
Search for "grease gun" on crc lists several. They're all probably the same, witht the exception of the Pace one.
Posted : 22/05/2009 10:31 am
Finish Line Premium isn't runny enough for Turners zerks and bushes, Prep M's the right stuff. Any micro-head attachment will do the trick, Halfords usually have them.
[url= http://www.chainreactioncycles.com/Models.aspx?ModelID=5957 ]This would do the job.[/url] You need to unbolt one end of the shock and swing it out of the way to reach the main pivot zerk unless you've the curved nozzle, but so what?
Posted : 22/05/2009 10:35 am
Mine's cheaper!
Posted : 22/05/2009 10:36 am
Where did you get your prep M? I'm running low and can't seem to find it anywhere?!
Posted : 22/05/2009 10:39 am
Ideally you want the curved one so you don't have to take things apart. I seem to recall mine came from the UK Turner importer, so I'd recommend giving Silverfish a call.
Posted : 22/05/2009 10:41 am
For
take things apart
, read
undo one allen bolt
Posted : 22/05/2009 10:51 am
Got my Prep M and grease gun for my Spot recently at Mountain Trax in Wokingham. Live nearby, but they have a website too, so check that or call them. Believe they got a few in last time.
Posted : 22/05/2009 11:11 am
cheers everyone!
Posted : 22/05/2009 1:54 pm
prep M from noahs ark ...cheap and v.fast delivery.
Posted : 22/05/2009 2:45 pm
Jon, you've got mail.
Posted : 22/05/2009 2:55 pm
