Hello, I already have the [b]RockShox Super Deluxe Coil RCT[/b].
Currently I weigh [b]69Kg (152lbs)[/b] and I have mounted a [b]Coil of 300lbs[/b], has it been a good choice?. I'm based on the following table::
I'm riding it on a [b]v4.2[/b] too.
Thanks.
Are you riding DH mostly? Is that with helmet, bag, shoes, pads etc on? Probably a touch soft if not
I'm riding for Enduro only :).
Up! :).
I ask because tomorrow I go riding a bike and wouldn't like break anything for having made a bad choice...:(.
They told me that for my weight the 350 lbs was the right pier ut I want to make sure.
Thanks.
Sorry for the error in first Post: "[i][b]I have mounted a Coil of 350lbs[/b][/i]"
It'll be fine, but whether it's 'right' depends on how you want it to feel.
I will only use it for Enduro. It was to know if the relationship of the chosen coil and my weight were correct.
Well, yeah, but you have no idea what they mean by 'enduro' and if it matches what you think it means. Just ride it and go from there.
It's just only a question of whether I made the right choice with that kind of coil, not more :).
According to Commencal you probably made the right choice. All I'm trying to say is that tables like that are usually quite general and meant as a starting point rather than being taken as gospel. Now that you're at that starting point go ride and decide whether the spring fells right for you. Chances are it will, but don't take it as a failure if you think it could do with being firmer/softer.
