Power spline crank ...
[Closed] Power spline crank arm removal
Truvativ Hussefelt. Seems to be some conflicting anecdotal advice on the www
Allegedly after removing the crank bolts the crank arms just slide off or they need a square-taper crank puller ๐Ÿ˜•
Just wondered if anyone actually knows
Ta folks
Posted : 17/02/2015 10:29 am
If they are powerspline, not ISIS (not come across a powerspline Hussefelt myself), then technically you'll need a square taper puller, but in reality they often fall off under their own weight (even had brand new, and unridden ones do it).Powersline BB's also have the lifespan of a mayfly too.
Posted : 17/02/2015 6:52 pm
