Ponderings while ch...
Ponderings while changing 17287 bearings again
Like many here, I find myself servicing or swapping 17287 bearings more often than any other. My particular 9nes are in Hope freehubs, but it's not exclusive.
I'm also running some (very) old Ti-Glide hubs and almost never touch the 6001 bearing which is 12288.
So, I got to thinking, if you could get someone to make steel axles to a tight enough tolerance and a little effort to retain end caps in hubs, maybe an extra o-ring, then bearings would last like they used to.
Would it really add an off putting amount of weight or inconvenience?
Posted : 18/01/2023 1:59 pm
Just me then? Thought I could have been on to something.
Posted : 18/01/2023 5:39 pm
I guess they are easy /quick to replace, so not something to worry about ?
Posted : 18/01/2023 5:44 pm
 Yak
Well yeah, but that's not how progress works. Lighter, stiffer, easier to use, more standards, more stuff, more expensive....less durable.
Posted : 18/01/2023 5:47 pm
I have a mate that kills axles so he got one made up in steel.
And, yes, I had to change a destroyed Pro4 inner freehub bearing at the weekend. Couldn’t get the race off on the end so had to swap freehub.
Posted : 18/01/2023 7:54 pm
If you have smaller balls they are less durable.
See ISIS vs square taper bottom brackets.
Posted : 18/01/2023 7:57 pm
Oh, I have some Ti-Glides on HED Jet Carbon TT rims. Years old, but not used any more.
Posted : 18/01/2023 8:46 pm
17287 is a lot of bearings to change. I'd probably give up at about the 1000 mark.
Posted : 18/01/2023 9:28 pm
Dammit @stevious, I scrolled down to say that!
Must be a very complicated suspension design.
Posted : 19/01/2023 10:18 am
