Hallo!
I want to buy the vpd 2.0 knee pad (the dh short version, which i guess is the same in sizing as the normal 2.0)
My measurements are:
38cm (15 in) 10 cm below knee
43cm (17 in) 10 cm below knee
Should i go medium or large.
I read contradicting sizing reviews.
Leg measurement and your pad size would be helpful
Hi
I have the VPD air, so this may not be that helpful.
Measured 10cm from the centre of my knee cap
15.5 inch and 18 inch.
I have mediums and they are snug - I would prefer a size between M and L. I found the L fitted, but I felt it would rub and move.
I hope that helps
Ive got those pads and on the same distance as yours I measure 40 below and 48 above.
Id not want any bigger personnally, they dont slip down but the top can drop behind my knee a bit sometimes on long pedals. Id probably go medium.
Actually id buy both and return one or just try them on in a shop.
Nickdavies what size do you have? Do you have vpd 2 or vpd 2 DH?
Order both, return the ones that don't fit.
In my experience its the only way to get pads to fit right.
