Pluging carbon bars...
[Closed] Pluging carbon bars for ends
Acceptable or not? An engineer can do this for me. Now obviously it will stop the carbon collapsing, but I'm not sure of the effect of clamping will have on the weave.
I'm only asking as the wider flats don't seem to be reinforced.
Posted : 14/02/2009 10:14 am
As an alternative, consider the Cane Creek Ergo bar-ends fitted to a set of lock on grips. The "inner" lock-on ring will be where all the controls are fitted (and hence should be strong enough), the Ergos fit on where the outer ring would be.
Posted : 14/02/2009 10:21 am
Absolutely fine, Truvative supply custom metal bar plugs with their Noir carbon flat bars bars for the same reason.
Posted : 14/02/2009 10:36 am
the weight weenie guys use a bottle cork cut down .
Posted : 14/02/2009 2:19 pm
I just trimmed/whittled a screwdriver handle down, then stuck it in with araldite. Stops the carbon crushing and works a treat.
Posted : 14/02/2009 4:20 pm
Specialized do some plugs too, not an issue at all.
Posted : 14/02/2009 6:52 pm
The Easton monkeylites have a thin alu tube in the end .. I run them with bar ends and Hope end caps. No probs at all.
Posted : 14/02/2009 9:38 pm
