Please Help with me...
[Closed] Please Help with me with Low/High Speed Compression
I have just got some new 2012 Fox 36 Van RC2 Kashimas
But with 26 low compression & 28 high compression clicks I dont know where to start, not even sure I understand it to be honest!!!
Please help!
Posted : 04/10/2011 10:46 pm
 nonk
http://www.mojo.co.uk/techtips.html
have you watched the vids on here?
Posted : 04/10/2011 10:50 pm
Have a look here
http://locotuning.co.uk/compression-glossary.html
Posted : 04/10/2011 10:53 pm
I have done yes, but its very basic!Is compression meant to be adjusted throughout a ride? Does it need constant fettling?
Posted : 04/10/2011 10:54 pm
I do understand the basics, but would like some peoples experiences with it on there bikes if you get what I mean!
Posted : 04/10/2011 10:55 pm
Low speed is for stuff like fork dive on braking, bomb holes etc where the suspension compresses more slowly.
High speed is for sudden impacts - hitting square edges, roots, rocks, landing jumps, etc.
Repeat a section of trail that has a mix of elements that will use both and play with the settings. Try full hard and soft for each and see what difference they make. No-one can give you exact settings as it will vary.
Posted : 04/10/2011 11:07 pm
yep i think i have got it now, i presume when setting my sag all compression should be turned off?\
Posted : 04/10/2011 11:13 pm
No, compression damping settings make no difference to your sag.
Posted : 04/10/2011 11:18 pm
And make sure you have the correct spring in for your weight.
Posted : 04/10/2011 11:54 pm
