Please help me plan...
Please help me plan 2.5 days in THE LAKES - there will be Hike-a-Bike
[#13535629]
Evening folks,
Heading to Kewsick in a few weeks and fancy getting a evening ride in on the friday and then 2 full days after that.
How does this all sound? Owt i should avoid or am missing?
Was thinking...
FRI
Leaving work early to take advantage of the long evening, so something like...
1. Skiddaw and Ullock pike (obvs easy to do from Keswick)
2. Keppel cove and down Stick Pass (park at Patterdale, then drive back to Kewsick)
3. Blencathra and down to Scales Tarn then Scales - maybe a bonus Latrigg on the way home for the win
I have
Any other options on the way to Keswick from the east?
SAT
Fancy heading up and over Griesdale Pike and then maybe one of these:
1. Ladyside Pike (looks to be a bit of a carry down at the start?), up whinlatter pass, Lord's seat, Barf, Whinaltter Garbonzo (is it open/ridable?)
2. Whiteside then Whin Ben (how techy?) probably back up newlands and down rigg beck
3. Crag Hill and Causey Pike (worth the effort? Or better to drop down to rigg beck and miss out causey pike?)
I did Hobcarton End the other week (ace) and have done Whitelees Pike a few times (also ace)
SUN
Keen to turn sticks pass into a big day out...
1. Park at Brothers water, up to hayeswater, Angle Tarn, Boredale House, Patterdale, Kepple cove,  Sticks Pass (maybe too much)
2. Park at Patterdale, up Grisedale, up dolywagon pike (hmmm), along ridge and down sticks pass
Posted : 20/05/2026 9:25 pm
tractionman reacted
Wow. I do like your suggestions . Some top routes there!
It might be slightly less driving ( though probably only the post ride drive is shorter really) by doing Stick west and then down Birkside on Friday.
Regarding Causey Pike, my comments on here   https://strava.app.link/AgP6OrAUi3b weren't too enthusiastic. I can't recall much about it, which probably tells you all you need to know.
Looks like I was much more enthused by GP and Whiteless  https://strava.app.link/sTKbtFKUi3b
SUN
I've done High Street and Helvellyn together, but TBH HS is dull as **** and horrendous if not parched or frozen, so Boredale Hause etc sounds better.
Perhaps start in pattersale, North up Ullswater Bridleway, then back over Boredale and then up Helvelyn?
I presume you're aware of Seldom Seen option on Sticks East?
If you want a proper big ride then there's shit loads of options for a Helvelyn double.  Eg
  https://strava.app.link/e4pjU4iVi3b
Up Dodds,  down Sticks, up Keppel, down Birkside
Posted : 20/05/2026 10:03 pm
Thanks @thegeneralist, will have a look through.
Posted : 20/05/2026 10:23 pm
Fri - all good options.
Sat - don't know enough on these to comment, but from memory (doing them on foot a while back) I don't think Causey Pike would be rideable
Sun - If you want a big day in that area go for Helvellyn twice. Option as mentioned above, or from Glenridding side to include Dollywagon and Grisedale. Or 3 times for Sticks, Birk Side and Dollwagon....
Personally I'd say this is the wrong direction. People may do this way if Dollywagon is too tech, but based on your other suggestions I expect that's not an issue.
Posted : 21/05/2026 9:45 am
I was going to say exactly that, but realised I don't have evidence to back it up.:-) I'm sure Mark does though!
I'm really keen to try Dollywaggon again and think it looks great. I've only done it once, and thought it was shit, but that was on a fully rigid bike with cantis and toe clips 32 years ago. I'm sure it'd be a helluva lot more fun on a Slash.
Posted : 21/05/2026 10:47 am
Also, while I'm not a big fan of the Dollywaggon steps myself, the lower bit of Grisedale is one of the finest descents (I've done) in the Lakes, so pushing up it would be depressing. I've done a Helvellyn loop from Patterdale (possibly even the full High Street climb, because I'm a sucker for punishment, can't remember) and then added Ullswater bridleway and Boredale Hause loop on. So a figure of 8 day of sorts - advantage being you can refuel in Patterdale, carry less, or sack off the second loop if you've had enough/broken self or bike.
Posted : 21/05/2026 11:23 am
Turns out I did do that... so long ago that I was still posting stuff on Strava: https://www.strava.com/activities/347859255
Posted : 21/05/2026 11:27 am
Thanks for the feedback.
Ok so Fri will ride from Keswick.
Sat - avoid causey. Think I will do whitelees and back up to whin latter then.
Sunday - double Helveyn it is.
Where is seldom seen @thegeneralist, not heard of that?
Posted : 29/05/2026 12:20 pm
I did the climb up grisledale a few years go to the bottom of dolly wagon. Thought it was nice actually. Pretty much all ridable. I may have remembered the last bit wrongly though.
I like the would of it as a descent though.
Posted : 29/05/2026 2:18 pm
Have a look on an OS map. You start off down Sticks east, but instead of following the Bridleway slightly south ( rightwardd) you continue dead east and up over a shoulder. Then veer ever so slightly ENE and descend into Glencoyn on the footpath. It passes right next to a farmhouse called Seldom Seen. A lot of people rave about it, but I'm not fully sure. It's really nice but I prefer my lakes rides more gnadgery and there's nothing techie on it till right at the bottom.
Don't get me wrong, if you git a pedal strike on the top bit you'd really regret it,  but it's not the slow tricky rocky gnadge that Birkside has for example
Aha Strava link....
: https://strava.app.link/DBMndlzCx3b
Posted : 29/05/2026 6:33 pm
Ahhhh thanks.
I was looking for it at on the grisledale BW. Found it now.
Thank you.
Posted : 29/05/2026 8:26 pm
