Play in Rear Suspen...
[Closed] Play in Rear Suspension
 gdm4
I have the slightest bit of play in the rear suspension on my Giant Trance. It is noticeable when I lift the rear of the bike from the top tube and I think I have located the movement from the link that joins the top of the rear shock to the meastro suspension bracket (triangular bracket). I have loosed the bolt that runs through right off and taken out and then put back and tightened up properly but the slight play is still there. Can anyone help?
Thanks
Posted : 23/06/2014 4:04 pm
The bushing in the top mount need replacing? (bizarrely the bottom mount doesn't include one apparently)
Bushings cost a couple of quid, a tool to do it a bit more (or take it to your LBS), though it can be replaced using sockets, if you want the cheap and cheerful. Find the tools and bushing on ebay.
Posted : 23/06/2014 4:19 pm
 gdm4
Thanks. Which bit is the bushing? Is that the piece within triangular bracket that the threaded bolt screws into? That's probably a daft question I know!
Posted : 23/06/2014 7:10 pm
The bushing fits inside the rear shock top eyelet
See the pictures in the middle of [url= http://www.tftunedshox.com/info/mount_kits_bushings.aspx ]this page[/url]
Posted : 24/06/2014 8:16 am
 IA
It'll either be the bushing or the bearing in the rocker, as it seems to be the first one to go on giants.
Posted : 24/06/2014 9:05 am
Agree. Definitely sounds like worn bushings, although I recommend you ask z1ppy where he gets his bushings from for "a couple of quid". In my recent experience you can add a zero to that price. That said, my LBS did then fit them for free.
Let the air out of the shock and see if the bearings feel rough when you move the shock in the mount manually. If they still feel smooth, it's a good sign it's the bushings rather than bearings.
Posted : 24/06/2014 9:12 am
ST, lots on the ebay but I bought my last lot from a bearing supplier, cheap as chips.
Posted : 24/06/2014 9:18 am
Bushing v bushing kit. When/why would you only need the former and not the latter?
Posted : 24/06/2014 9:19 am
because the hula hoop wears first - always teh case, hence why they are sold individually
Posted : 24/06/2014 9:21 am
If you change the bushing when there is only a little play you don't need the whole kit.
Posted : 24/06/2014 9:22 am
the top hats
also wear alongside the bushing, on some bikes it happens more so than others. You only replace the 'kit' when changing your bushing doesn't remove the play (& it isn't coming from elsewhere) though IME it obvious that the top hats no longer fit snugly into a 'new' bushing.
Posted : 24/06/2014 9:23 am
Glad I came on this thread then. Sounds like this knowledge will save me some money.
Ta
Posted : 24/06/2014 9:27 am
Bushing replaced in Oct 13 £14 from LBS, bushing replaced by mate in May 14 £4 less the £10 labour - get the wee yellowish ones they are stronger. Learn how to do it and buy 3 or 4, I ride a Giant Reign. LBS rides a SC and reckons he went through one in 2 months.
Posted : 24/06/2014 9:30 am
AS above it'll most likely be the shock bushing although check the saddle and linkages first
A word of caution with the heavy-duty ones if your shock linkage is made from cheese like the one on my Cannondale the bushes will cause premature wear to the linkage
Posted : 24/06/2014 9:49 am
Is it by Alan Bennett??
[/notenoughcultureonthisforum]
Posted : 24/06/2014 9:56 am
 gdm4
Thanks everyone really appreciate your help.
Posted : 25/06/2014 7:02 pm
 gdm4
Got the bushing replaced in under 2 minutes and for a fiver by the super friendly and knowledgable people in a bike shop Rawtenstall (Ride On). Thanks everyone for their input and solving my problem.
Posted : 01/07/2014 11:27 am
maxtorque - Member
It would be Play On Rear Suspension if it was.
Posted : 01/07/2014 12:28 pm
