PlanetX Geoff Bars
[Closed] PlanetX Geoff Bars
I got a set of these for my Fat/29+ bike & I'm just not feeling the love. Seem OK on the long fire rd climbs, take my bike packing gear fine but their lousy on the singletrack & the do seem very low.
Anyone else running them? How'd you find them.
Posted : 19/10/2020 9:56 pm
They (or the Jones originals) need to be at about saddle height and tilted backwards by 10-20 degrees.
I put a set on my fat bike but they were too low as the bike was second hand from someone a little shorter than me and the steerer was too short. I swapped them for Jones Riser bars which raised things by 6cm and then were fine.
Posted : 19/10/2020 10:05 pm
I bought a set to help with tendonitis in both wrists and the extreme sweep of the bar certainly helps with that. I agree that they do feel strange when attacking singletrack or anything technical. I put 10mm extra stem than I usually run with flat bars and that's helped a lot...Maybe just a case of persevering and getting used to the shape/sweep.
Posted : 20/10/2020 10:22 am
 Spin
I love mine but bars are pretty personal I think. I've got them on a do everything rigid 29er and really like the variety of positions they give for different types of riding. I did worry a bit about how they'd feel on more technical terrain but I've ridden loads with them now and I don't think it's the bars holding me back.
Posted : 20/10/2020 10:28 am
I have a set of these and the angle you set them at is crucial. I found that I needed to have mine tilted quite a lot to match my natural wrist angle, in that position they are great but they are a bit low, so I am going to add a spacer under mine.
I also run the brake levers at a much steeper (ie pointing down) angle to match my wrists. If I have them flat like on my big bike, it forces my arms into a funny position.
Just did two days fully laden bikepacking and they were ace.
Posted : 20/10/2020 10:30 am
I bought some for a Longitude in the hope of doing a spot of bikepacking/touring. Didn’t like them first off. Didn't have any long grips so bought some cheap foam grips and cut to size just to try them out.
Took a while to adjust the rotation and finally settle on a stem. I gave them a year, switching back and forth between the Geoffs vs a carbon flat with (Ergon GP3) bar ends. I wrapped them with bar tape and fitted Ergon GC1. I tried again. Never got any touring in after all but I’ve taken them on a good few mixed-terrain/gravel rides and there are plenty of hills hereabouts.
All said and done - found that I tend to choose and fit the flat bars w/bar ends more often.
The Geoffs (when optimally setup) are undoubtedly comfortable as far as posture is concerned, but as far as riding-comfort is concerned - for me they’re a little too wide (I can cut) and a lot too heavy/rigid (can’t help that) for my requirements. The generous back sweep tends to plant me harder on the saddle. Which is not touring style. I like to more easily balance weight-distribution fore and aft (between saddle and grips). The loop helps in this respect but I tend not to spend much time there as I would on (say) the hoods of drop bars on my road/gravel tourer. The wrist-rotation is perfect on hoods.
The Geoffs - possibly ideal in a zombie apocalypse. So (2020 being a taster) - I’ll hang on to them for the moment 🥁
Posted : 20/10/2020 10:45 am
I found them a little low with a flattish 35mm stem. I've just altered my set up to a short but high rise stem. 60mm with around a 35 degree rise. Transformed the handling. I can now pop the front end up and wheelie making the ride livelier.
Posted : 20/10/2020 5:00 pm
I have Jones on my fatty and Geoffs on my 29+ - as said having them at an angle to get a more natural wrist angle helps a lot, plus I have the Ergon angled grips. I've come down some pretty steep descents like trails at the Golfie on my fatty - my bars were probably the last thing I was worried about.
Posted : 20/10/2020 7:46 pm
Cheers folks. I'm thinking I'll try and source a far steeper stem then persevere for a bit longer.
Any suggestions for steep rising stems?
Posted : 21/10/2020 8:04 pm
Put some on my HT for bikepacking duties and big fat grips to help with wonky elbow issues. Bit of fiddling about with angle but I like them and find no problem hammering down trails. Took a few rides to get used to them though.
Posted : 21/10/2020 8:22 pm
The BBB ones that were around are fine. I'm still using mine with a set of drop bars on an MTB frame.
Ritchey are also fine, but IME the bolts round out easily and are worth replacing before they do.
Posted : 21/10/2020 8:36 pm
Funnily enough I was looking at this https://www.tredz.co.uk/.BBB-HighRise-MTB-Stem_60927.htm from BBB
Posted : 22/10/2020 10:04 pm
Before I went back to a sensible 90mm I tried this ‘Wake’ monster
Cheep and cheerful. Made me feel Dutch.
Christ it’s a shocker. And that light pointing down, what the heuh!
Posted : 23/10/2020 5:09 am
