Got the pro carbon sl and after 5 months, albeit about 5000 miles, the front hub bearings have gone AWOL, local LBS says their chart doesn't recognise the bearings in them. Anyone help out here. Hub is superlight planet x
Are they sealed cartridge style bearings? There should be a code somewhere, either on the outer ring or on the black plastic cover? Find this code and then get in touch with a bearing supplier (yellow pages/google), maybe work out few quid cheaper than going through a bike shop.
Have you tried emailing Planet X?
They're generally very responsive.
any bearing supplier Outside diameter/insiside dia/width.seal type. you dont need the numbers
there's a 'feedback' tab on the p-x site now (left hand side) - if you find out can you post up on here? Be interested if there's any rear hub drawings about - I want to service the freewheel (it's getting even clickier)and and would like to know what to expect.
