Pipedream Sirius S5...
Pipedream Sirius S5 anyone actually got one?
Hello all.
Has anyone actually got one?
The website is a bit patchy on details - what is the seat post diameter? Are they a boat anchor? Is the silver fox like Philip Schofield or shiny?
Posted : 10/11/2020 9:50 pm
How are you supposed to work out the seat angle with a bent seat tube?
Posted : 10/11/2020 11:18 pm
Seat post size is on the technical info pdf, it 31.6mm. Can't help with the other questions though
Tom
Posted : 11/11/2020 8:08 am
Huh. Thank you and apologies, I've been impatient as they've updated the website by the looks of it.
Flat cap green is definitely flat cap green from ST and their own website.
Would still be good to get a frame weight, they seem understandably super busy as I've not been able to get through.
Posted : 11/11/2020 9:16 am
They must be fairly lightweight - theres a 100kg total rider weight limit.
I'm dangerously close to that with standard ride gear.
Posted : 11/11/2020 1:24 pm
Maybe, though the Moxie has the same limit right?
Posted : 11/11/2020 1:46 pm
I dont know. I just read it at the bottom of the Sirius page.
Posted : 11/11/2020 1:52 pm
Looking at the chainstay bridge I'd expect them to come in just under 3 kg
Posted : 11/11/2020 5:51 pm
Hmm. Near enough what the bloke at Stif said for the Squatch frame. Very tempted by the Squatch in the bone colourway...
Posted : 11/11/2020 6:22 pm
What do people think that seat angle really is? Might be 77.5 to seatclamp but must be 3-4 degrees slacker at full extension?
Posted : 11/11/2020 6:25 pm
Would think so, though it'll steepen as the fork sags being a hardtail so perhaps not too far off that.
The Squatch is 78 degrees at full extension, so will only get steeper.
Posted : 11/11/2020 6:33 pm
They've only just posted a build on their Insta yesterday so I doubt there are many in the wild yet.
Posted : 11/11/2020 7:06 pm
Can anyone explain why the frames have same length headtube and chainstay's across sizes?
Posted : 13/11/2020 11:01 am
I cannot explain that - though guessing about the chainstays, the designers wanted something specific from the ride. And, of course, they are variable from 425 - 441mm.
Spoke to their office today. The tubes from the seatpost back of the bike are the same as the Moxie. The downtube and toptube are slimmer, they've dropped a gauge down respectively from the Moxie. They're also quad-butted rather than triple-butted. So the frame will be lighter, though they're not sure quite by how much. Scales arriving this afternoon so expect something on the website.
Also, more frames on a boat which will be available in 3 - 4 weeks.
Posted : 13/11/2020 12:25 pm
Oh so tempted, looking for a hardtail to replace my Salsa El Mariachi, single speedable, dropper post routing, longer and slacker................boost spacing, I'm oot!
The search continues, I might take a look at custom build, possibly Marino.
Posted : 13/11/2020 2:24 pm
Ah man.... My el mariachi is still my favourite bike I've owned. It was nicked (whyIoughta) otherwise I'd still have it. Wish that Salsa still made them.
I've got a Genesis Fortitude I'm similarly tempted to replace (and probably regret), plus a Cotic FlareMax frame I'm going to shift (and probably regret).
Posted : 13/11/2020 4:28 pm
jimmiyjuju, Would have bought the Sirius if it wasn't for the boost spacing, both my wheelsets are for 135/142.
El Mar is a cracking bike, on my second frame now, just after something a bit slacker/longer.
Might try fiddling with the Marino site and see how much one of there frames costs.
Posted : 13/11/2020 7:51 pm
@inbred853 If it's just the boost spacing that's putting you off but your existing wheelsets are thru axle why not just use boost adapters?
I get that it's not the nicest solution but if that's the only thing you dislike about the frame I'd give it some consideration.
Posted : 13/11/2020 8:19 pm
Agreed, you will struggle finding modern geo with "old" standards off the shelf. I bought a sherpa and put my old hope pro2 evo wheels on. Used hope adaptors and took about 10 minutes to sort with a spoke key.
Posted : 13/11/2020 8:31 pm
Was thinking the same, adapt the wheels and give me the el mar.
Well almost the same...
Posted : 13/11/2020 8:34 pm
jimmiyjuju, we'll see 🤣🤣 it's a 15.5" btw and yes I'm a short arse.
Do you not have to re-dish the wheels and faff about with disc rotor spacing or is it a simple adapter swap for 135/142 to 148🤔.
Posted : 13/11/2020 8:52 pm
There are different kits available depending on your hubs. I'm running a generic kit with an axle spacer on each side of the hub plus a disc spacer up front and a 6mm spacer and disc spacer at the rear. I did redish the rear wheel to keep the cassette in the correct position but it's only 3mm.
If there are end caps available for your hubs you probably won't need the extra spacers. The cheap kits I used came with longer disc bolts too.
Posted : 13/11/2020 11:14 pm
The stack does see very low on the Sirius (586 mm), which is the same for all 3 sizes due to the same head tube length being used. Looking at similar types of frames, none go below 600 mm stack even on the smallest sizes. Why is the stack so low on the Sirius? The low stack is probably OK on the smallest size but doesn't appear to make sense on the 2 bigger sizes.
Posted : 14/11/2020 11:10 am
The geometry is based on 485mm a2c fork, probably explains it. Their CrMo fork option is around that length but most 120mm suspension forks will be longer.
That info is hidden in the FAQ section, probably should be on the geometry table to be clear.
Posted : 14/11/2020 11:45 am
@drewd, thanks for the info, to much faff for me though. I'll continue to look for a frame with 142 x 12 back end.
Posted : 14/11/2020 3:00 pm
Pre-ordered a frame in Longer. Look forward to riding the bike early December.
Mate of mine also pointed out the geometry measurements were essentially based on the 100mm suspension-corrected rigid fork. The website really should be clearer.
Posted : 15/11/2020 10:25 am
@jimmyjuju, don't look there is a medium El Mar on the bay at the mo.
Posted : 15/11/2020 7:50 pm
Then I will not look.
Posted : 16/11/2020 8:56 am
Mine arrived yesterday, long silver fox. The frame is a work of art, lovely paint and looks mint without the gussets. Frame with all the hardware comes in at around 6.5lbs.
[url= https://live.staticflickr.com/65535/50626981163_f9d76f71ac_h.jp g" target="_blank">https://live.staticflickr.com/65535/50626981163_f9d76f71ac_h.jp g"/> [/img][/url]
[url= https://live.staticflickr.com/65535/50626981208_78738467c3_h.jp g" target="_blank">https://live.staticflickr.com/65535/50626981208_78738467c3_h.jp g"/> [/img][/url]
[url= https://live.staticflickr.com/65535/50626981223_f45ca44352_h.jp g" target="_blank">https://live.staticflickr.com/65535/50626981223_f45ca44352_h.jp g"/> [/img][/url]
Posted : 21/11/2020 7:08 am
The geometry is pretty wild, I'll be running a SID 120 (35mm), will post full build pics and ride report later.
Using the geo calculator, and website geometry being based on a 485mm a2c fork, the SID (531mm a2c) comes in at 63° HA unsagged and 64° sagged at 20%! That's 2 degrees slacker than the 140mm travel 2017 BFe 650b it's replacing.
UNSAGGED
[url= https://live.staticflickr.com/65535/50627857857_fa78bc23da_h.jp g" target="_blank">https://live.staticflickr.com/65535/50627857857_fa78bc23da_h.jp g"/> [/img][/url]
SAGGED 20%
[url= https://live.staticflickr.com/65535/50627857867_951e18cb5c_b.jp g" target="_blank">https://live.staticflickr.com/65535/50627857867_951e18cb5c_b.jp g"/> [/img][/url]
Posted : 21/11/2020 7:16 am
Really like the look of these but seem tiny to someone 6'2" and 34" inside leg?
Used to riding something with a 21" seattube.
Spose it gives you scope for fitting a 180 or 200mm dropper?
Be interested to see a tall guy with one and their verdict.
Thanks,
Max.
Posted : 21/11/2020 7:28 pm
Thanks @Yorkshireripper. Frame looks spot on.
Look forward to more pics and ride report when you can manage them.
Jimmy
Posted : 21/11/2020 10:40 pm
The geometry is pretty wild, I’ll be running a SID 120 (35mm), will post full build pics and ride report later.
Using the geo calculator, and website geometry being based on a 485mm a2c fork, the SID (531mm a2c) comes in at 63° HA unsagged and 64° sagged at 20%! That’s 2 degrees slacker than the 140mm travel 2017 BFe 650b it’s replacing.
I suspect that the faq refers to the old sirius. Below the geo table it says: "Will it work with a 130mm 29er fork? Yes, but it’ll raise the BB and shorten the reach by approximately 5mm and slacken the head and seat angles by approximately 0.5°."
Suggests to me that the table is for a 120mm fork if you go by the 10mm = 0.5° approximation. Whether this is a sagged fork or not isn't mentioned but I'm going to guess that the 64mm BB drop suggests sagged.
Posted : 21/11/2020 11:11 pm
It's hard to say on the geo, website could be more clear. Cotic have this spot on in my view, they tell you that the measurements are sagged (which makes sense with a hardtail) and you can toggle the travel to see what the difference is with each fork.
I wanted a 29er hardtail to replace my 650b BFe, which up until the Sirius was the best hardtail I'd owned. The BFe was the hardtail equivalent of my enduro bike, pretty much same geometry and parts which was good for crossover, but I wanted something that I could do the odd XC/endurance type event on and 29 makes sense for this. I still wanted something slack enough for the steeps so I was set on a SolarisMAX but was put off my the long chainstays and tank like ride reports on the forums. I then started looking at the Sherpa but when the Sirius popped up the geo looked exactly what I was looking for. Added bonus of being able to tune the chainstay to tyre size and also run singlespeed. I ran it at 430mm chainstay which with a 2.3 Maxxis Aggressor gave sufficient tyre clearance with no rub on a 23mm rim.
The fit for me at 173cm was spot on, pedals nice with the steep seat tube angle, I ran with a 40mm stem, could maybe go to 50mm. The front end is fairly low but with 20mm rise bars was OK, I could maybe go to 30mm rise, I was a little over zealous with the steerer tube cut. It looks and feels slack when you sit on it, but when I rode it I felt right at home coming off the BFe. It's my first 29er so that needs to be factored in, but it was a super smooth ride. I took it to Gisburn for some hardpack and it was the first time I'd ridden there on a hardtail where I didn't want to quit mountain biking afterwords. There are some fun bits, but a lot of it is a rough old slog. It was great in the swoopy stuff, felt like a 29er when it needed to be but was super nimble in the tight trees which I was surprised by. I built it up with a mix of parts off the BFe, some WTB i23 on Hope wheels I picked up cheap from Stif and a winter throwaway SX drivetrain which weighs a tonne. I swear that cassette is like 2lbs. Its built to survive a Yorkshire winter but could be lightened up. The SID is amazing, didn't feel the need for any more travel, but there are probably stiffer options out there.
Anyway, I love the bike, looks sweet and have a new chainstay protector in the post 🙂
[url= https://live.staticflickr.com/65535/50631483493_0febae6807_k.jp g" target="_blank">https://live.staticflickr.com/65535/50631483493_0febae6807_k.jp g"/> [/img][/url]
[url= https://live.staticflickr.com/65535/50631483373_c4ff679ba2_k.jp g" target="_blank">https://live.staticflickr.com/65535/50631483373_c4ff679ba2_k.jp g"/> [/img][/url]
Posted : 22/11/2020 8:58 am
That looks purdy. 😎
Posted : 22/11/2020 9:01 am
Lovely. Been pondering a singlespeed 29er with modernish geometry and considering this versus the Stanton Sherpa as realistic options, so great to see some images.
Posted : 22/11/2020 9:08 am
Very nice. If i hadn’t already ordered a Sherpa, this would be a serious contender. I’m also building around the new SIDs - pleased to hear you like them.
Posted : 22/11/2020 10:09 am
Great to hear, thank you for the write up. Bike looks sweet in silver! Looking forward to seeing the spangly black version in the flesh...
Posted : 22/11/2020 9:16 pm
Just bumping this thread to see how you're getting on with the bike @YorkshireRipper? Still idly considering a build on one of these some time this year...
Posted : 12/01/2021 9:56 pm
Looks fantastic...what's included within that hardwear figure? Just bottle bosses and a seat clamp? or headset?
Posted : 13/01/2021 9:31 am
Looks really nice that @YorkshireRipper. How does it compare to the likes of Cotic, Stanton etc in terms of ride quality? My Stanton (Switch9er) is fun but definitely harsher to ride than the Solaris max it replaced.
Posted : 13/01/2021 3:59 pm
6.5lbs (2.95kg) was with dropouts etc, not including headset and seatpost clamp. I built it up with a SID which is super light, but for winter an NX/SX drivetrain which weighs a tonne. In summer I'll maybe put a lighter groupset on but it's never going to be that light, it's steel after all. I bought it as an all-rounder that could do the odd XC event, so not too bothered by the weight. I don't notice it.
Overall I'm loving the bike, super comfortable compared to the BFe but that's not a direct comparison, not ridden a SolarisMAX or Sherpa to compare. My GF has an ally NS Bikes Eccentric Evo 29 and noticeably more compliant than that. The short backend makes it feel smaller than a 29er and better in the tight stuff than I expected.
The SID is a great fork, but I do sometimes think a 120mm Pike would suit the frame better as it's so capable due to the geometry.
Posted : 14/01/2021 6:51 am
Not mine but I wish it was 😻
'Inspired' by my SS Moxie 🤣 The Sirius suits it a bit better though. Built to fairly easily have gears dropped on.
Posted : 14/01/2021 7:59 am
Looking nice @pigyn, similar SS build to something I envisaged. Seeing your moxie actually got me thinking down this route in the first place, something for similar terrain to you but always think the moxie is a bit overkill for 90% of local stuff. How do you find the dropouts/tensioning for singlespeed? And rigid up front on the moxie - how's the pipedream fork?
Posted : 14/01/2021 10:11 am
Crikey that is Uber cool, congrats 👏 I’m concerned about the lowish stack height which based on Pipedream website is 586 vs current bike an On-one Scandal which in a large has a stack of 628mm. I don’t know if these are like for like comparisons on websites as no more details available...can anyone help please?
Posted : 02/02/2021 9:23 pm
I'm looking at one of these and came across this thread, does anyone have any more reviews?
Cheers.
Posted : 26/05/2021 10:27 pm
That's my one in the link pigyn posted. Had it about 4 months now and really like it. Been used for lots of different stuff, local rides and playing around in the woods, bikepacking, Torridon, Golfie, Dunkeld, snowboarding access and general biking. It's been singlespeed, geared, rigid and hardtail and good in all versions. It climbs really well, good on technical climbs and is excellent on descents, while not a downhill bike. It's heavier than I hoped but to copy what people say a lot these days you don't notice it. Previous bike wasn't as modern geometry and 27.5 so was concerned it would be difficult going round corners, flop around going up hills, impossible to wheelie / manual and uncomfortable on flats but no issues at all while a better position on steep descents. If you've got any specific questions let me know.
Posted : 27/05/2021 4:47 pm
Thanks @jamesybob, I think I'll order one then build it up over the next while when funds and parts are available. I just need to decide on the size and colour now 😬
Posted : 27/05/2021 7:08 pm
No worries. That sounds like a good plan. Just been out for a ride on mine and still all good.
Posted : 27/05/2021 8:31 pm
I had a 631 Sirius painted a ti sort of colour. It really looked like ti. The paint job was stunningly done.
Now I'm triggered 🙁 sold bike sadness all over again.
Posted : 28/05/2021 6:34 am
Turnerfan1
Really like the look of these but seem tiny to someone 6’2″ and 34″ inside leg?
6'1" and 34 inside leg. Rode an 18" Sirius with 26 wheels and a Rockshox Rev U-turn 85-130mm. 80mm stem. Boom. Loved it.
Posted : 28/05/2021 6:36 am
I've been looking at maybe getting myself a Sirius but I was a bit concerned about the earlier comment about the 100kg weight limit as it has been a while since I've seen 100kg. Anyway I contacted Pipedream for clarification and this is their response, just in case anyone else is similarly concerned.
There's not a weight limit per se and I don't know how the rumour/misinformation came about. Our frames are tested and comply with ISO 4210-2.
ISO 4210-2:2015(en) Cycles — Safety requirements for bicycles — Part 2: Requirements for city and trekking, young adult, mountain and racing bicycles.
In producing this International Standard, the aim has been to ensure that bicycles manufactured in compliance with it will be as safe as is practically possible. The tests have been designed to ensure the strength and durability of individual parts as well as of the bicycle as a whole, demanding high quality throughout and consideration of safety aspects from the design stage onwards.
Frames manufactured by Pipedream Cycles Ltd are tested and comply with BS EN ISO 4210-2
The test load is 1200NM which equates to 122kg.
Posted : 01/08/2022 3:00 pm
