Pinder v Fox (again...
[Closed] Pinder v Fox (again, briefly)
 -m-
James annan calculates a force od 1800N and cannondale give almost twice that figure for the force acting to push the wheel out of the dropout. Easily enough to lift the weight of the rider and bike. I can't see any flaw in either set of calculations
Even if these calculations of force are correct (and the fact that 2 people have produced results that differ by a factor of 2 suggests that there's a lack of agreement on how to do this), in what direction are they acting?
Even in a 'vertical' dropout fork, the slot is typically in-line with the fork leg (Annan's involvement/interest originated in his custom fork with a backwards sloping dropout...). Given that the caliper is typically mounted on the back of the fork leg the force is going to be acting at around 20deg away from the perpendicular to the dropout. Although [i]part[/i] of the force is acting downwards, [i]more[/i] of it is acting into the back of the dropout.
Posted : 15/02/2009 8:08 am
In both cases the force quoted is the resultant force in the direction of the dropout. the difference is due to a difference in max deceleration used to calculate the force
Posted : 15/02/2009 9:49 am
 mrmo
stoner, i know the case revolves around the angle and placement of the dropout, and how the braking force acts so that it pushes the wheel out. Just unable to get my head round how the QR got so loose as to be able to come out without the rider noticing?
My experience is that when a wheel is no longer secure it is noticeable.
Fox paying out suggests they weren't confident of winning, which implies that there might be an issue, it might need a certain set of conditions to have been met, but there is something about dropout design and disk brakes that could be an issue.
Posted : 15/02/2009 9:50 am
Have you ridden The Gap? It's quite bumpy.
Posted : 15/02/2009 10:04 am
 IWH
Which I'd have thought would make it all the more obvious when something wasn't right on the bike in question...
Posted : 15/02/2009 10:51 am
I find this debate very depressing and can only wish Russ well and hope that the outcome helps ease his situation in any way possible.
Posted : 15/02/2009 11:04 am
 -m-
OK; but presumably we are saying that this directional force is in the first instance created as a result of the interaction between the pads and disc rotor, creating a pivot point. A component of this force is then acting in a particular direction, in line with the dropout. This component will, clearly, be smaller in magnitude than the original force. So... if the pad/disc interface is sufficient to cause the larger decelerative force in the first place, how does the (smaller) component of this force become sufficient to break that same interface? Particularly when that directional force component must also overcome the clamping force of the QR at the same time?
Or am I missing something?
Posted : 15/02/2009 12:17 pm
leverage ratios M
Posted : 15/02/2009 12:22 pm
 -m-
leverage ratios M
In what sense?
Posted : 15/02/2009 12:34 pm
James Annan describes it better than I can.. Its to do with how far from the effective pivot the force is applied.
Posted : 15/02/2009 12:51 pm
 -m-
In Annan's own 'analysis' he states that the force at the disc is 2460N, whilst the force at the dropout is 2000N. If my understanding of his argument is correct, he is stating that this 2000N force, created as a result of the interaction between the pad and disc, is sufficient to overcome that interaction.
So effect is bigger than cause?
Posted : 15/02/2009 12:53 pm
Page 2 / 2
