I went to wind out the travel today on my coil pikes for a bit of downhill singletrack only to discover the forks wouldnt wind out. I then gave the dial a wiggle and it skipped back a notch and shortened the travel. After i little more perseverance and trying everything i could think of at the time i ended up with the forks wound down to about 105mm and unable to shorten or lengthen in travel.
Anyone else experienced this? Or does anyone have any general advice?
Posted : 02/03/2010 7:37 pm
Duncan unscrew the allen key bolt on top of the u turn and take off the u turn bit, carefully as there are small ballbearings in it. Take them out and put some grease around them. Replace ball bearings and u turn adjuster
Posted : 02/03/2010 8:56 pm
thanks, will give it a go
Posted : 03/03/2010 7:24 pm
