2018 pike, not too sure from the spec chart whether it’s 5mm oil per leg or 10mm? Anyone help please.
Just put 10cc in. 5 isn't worth having.
Thanks Onzadog. 10 it is.
Might have it stamped on the foot bolt ? I might be dreaming though.
They originally said 5ml damper leg and 10ml air side.
A year or two later that changed to 10ml each leg. 👍
I thought I’d seen a vid on YouTube saying 5cc a few weeks back but as Onzadog said it doesn’t seem like it’s worth the effort for that amount!
The comment above is correct, it was originally 5cc. However, even before they upped it to 10ml, that's what I 2as using anyway.
It's not easy to come by in the UK, but Motorex Supergliss 100 is about the best stuff you'll find for the lowers.
