Pike 454 air leak -...
[Closed] Pike 454 air leak - diagnosis.
Resurrecting forks for a build and when they were last used (apart from generally being ready for a lowers service and oil etc) they had developed an air leak such that a normally sagged fork, wound down to 110 to earn the descent with would not actually extend when wound back out - unless you shook it and then it'd be obviously under-pressurised. No rough feeling and no stanchion damage.
Based on the SRAM tech stuff, I'm thinking this is the o-rings on the air piston - although i've never investigated/tried the heavier oil to see if it improves briefly trick.
Any other ideas? Or does my diagnosis sound about right?
Posted : 06/08/2013 11:40 pm
Sounds like O-ring seals, only way to tell would be to service really.
Posted : 07/08/2013 12:06 am
what i figured. Just getting ready to order parts and crack them open, I wondered if the o rings sounded sensible.
Ta! ๐Ÿ™‚
Posted : 07/08/2013 12:11 am
had something similar with some dual air revs, 1st service didn't fix it as 1 O-ring was just not seated right. There isn't much else to them really.
Posted : 07/08/2013 12:13 am
I was intending to go with the seals and oil Refresh kit from TF anyway, is the full "Reba/Rev/Pike Air U-Turn Service Kit" necessary as an addition to get teh air piston o rings?
I'm guessing that the answer is "no, but it's a good idea..." ๐Ÿ˜‰
Posted : 07/08/2013 12:33 am
no idea really on the kits, I did it at the LBS on a quiet afternoon with the big box of O-rings...
Speak to TF/LOCO direct for the best info.
Posted : 07/08/2013 12:35 am
Lol. Ta, Mike...
Posted : 07/08/2013 1:24 am
Aren't Pikes coil, not air???
Posted : 07/08/2013 6:12 am
Pikes have been air or coil over time
Posted : 07/08/2013 6:15 am
mine were fine after seal change, losing pressure etc
i used these on my 426 pike air forks and rebas
http://www.ebay.co.uk/itm/Rock-Shox-Reba-Race-O-rings-Seals-Crush-Washer-kit-/181175059850?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item2a2ee0058a
had 2 sets and they were perfect, all the seals are present + bottom gasket ring
Posted : 07/08/2013 7:06 am
Sumtimes the valve needs changing try that first take one off an innetube an swap it see it that works of not then stop them down
Posted : 07/08/2013 7:09 am
 LoCo
Check the inside of the uturn air tube for scores as well as this can cause air transfer even with me air seals fitted
Posted : 07/08/2013 7:18 am
Thanks guys, I'll let you know howit goes...
Posted : 10/08/2013 8:07 am
