Pedals that last lo...
[Closed] Pedals that last longer than DX spd
Morning all,
Loads of play in a DX pedal and I reckon it's only done about 1000 miles. Not the first time.ive had this happen with a set!
Are the xt/xtr trail pedals any better?
I know you can service them, but can't be bothered with pedals that need stripping and rebuilding every month or two?
Posted : 09/09/2017 7:52 am
Original DX.
Immortal.
Posted : 09/09/2017 7:59 am
If you are doing that kind of mileage in a month or 2 then it won't just be your pedals needing some servicing - and given the mileage in that timeframe, that doesn't sound unreasonable as that volume of mileage is reasonable.
Have they been serviced already or are they new and now needing done? I suspect the volume of grease in them from brand new isn't as much as they could have, so making sure they are filled will certainly see them last far longer.
If you can't be bothered servicing kit then your maintenance bills are going to be rather high and your spares drawer is going to grow massively, spending the 15 minutes (if that), refilling with grease will see them last much longer.
Posted : 09/09/2017 8:18 am
CB Mallet DH, better in every single way and 100% rebuildable in under 15 mins when bearings/bushings need changed. I get 1-2 years easy out of a set of bearings.
I've never serviced a pair of Time pedals.
I've never worn out a pair of Time pedals.
I only use Time as my clipless pedals.
One pair is around ten years old now.
Make of that what you will.
Posted : 09/09/2017 8:22 am
Thanks for that. Really helpful.
Spent a whole day doing maintenance on 4 bikes 2 weeks ago. Swapping a bottom bracket today. Bled a set of brakes mid week.
Servicing pedals is one job too much, hence my original question about if the xt ones last longer than DX?
Posted : 09/09/2017 8:37 am
 Euro
Original DX.
ahem...
Posted : 09/09/2017 8:39 am
IME yes they do, ive got about 4 pairs of xt pedals and the oldest fell apart after about 3 years. Tend to wear out the clips before bearings.
I'd look at nuke proof though, I've switched to horizons on the big bike as I wanted a bigger cage than dx and I'm really impressed, still use shimano cleats so they work on the other bikes with the same shoes.
Posted : 09/09/2017 11:32 am
Cheers, I'll look at nukeproof, anyone else experienced xt lasting longer?
Posted : 09/09/2017 11:41 am
Like me then, you dodged the shoddy QC bullet of Times from recent years, my ATAC XS Carbons are still going strong. 8)
Posted : 09/09/2017 11:44 am
PD-M520 - was a thread about them the other day - should survive the imminent nuclear holocaust.
dunno, I'm only up to 10 years on my XT SPD across 2 bikes, and are near perfect. the M520's on the other bike were a better deal though.
never opened either of those up, and never regreased.
edit: oh and for ones with platform cages, M545. Lasted forever, until I did service them (didn't need it, just had that urge to take them apart). Busted seals putting them back together. I'd wager they'd be perfect after 15 years.
Posted : 09/09/2017 12:00 pm
Just adjust the bearing preload - really quick and simple. You need a tool to remove the axle assembly dip from the pedal body to do it, but really quick to do, and much less wasteful and expensive than replacing bearings and bushings in other pedals.
Posted : 09/09/2017 2:54 pm
