Parts-Bin DJ/Pump T...
[Closed] Parts-Bin DJ/Pump Track build
[#11649392]
So my Planet-X 25th Anniversary Jack Flash arrived today, along with some tyres and bargain wheels from @singletrackmind (thanks Rob!!).
The rest of the build is definitely parts-bin stuff though.
I've got some 8 speed SRAM stuff to throw on, SLX cranks (converted to single ring), Shimano M365 brakes, Nukeproof bars, Suntour XCR forks and lizard skins grips.
Just waiting for a headset to arrive as that was one thing I didn't have spare.
Not usually a fan of Tan-Walls, but thought the Halo's looked cool and would suit the bike.
Pretty impressed with the frame too - seems well made and I like the industrial look of the head tube gussets.
Will post some more pics when I start building.
Posted : 01/01/2021 12:02 am
That should build into a nice little bike. It reminds me of my old Dr Jekyll.
Posted : 01/01/2021 12:22 am
I regret selling my DMR trailstar (10 years ago) so I'm now looking to get another pump track/dirt jumper. Im really close to ordering one of these Jack Flash frames, how has your new ride treated you? Reccomend the frame or should i look elsewhere?
Posted : 16/03/2021 9:48 pm
don't bother with 8 speed, single speed is all you need, and the derailleur with get knocked/bent/broken
keep it simple
Posted : 17/03/2021 9:39 am
Cheers bud
Anyone else have on of the new Jumping Jack Flash 26" frames?
Posted : 19/03/2021 9:21 am
I just finished building up mine a couple of nights ago (OK, it's not quite finished as I still need to sort the brake hoses and, probably, give the wheels a little love on the truing stand) but haven't had a chance to get out on it yet.
It's the first build I've done where I needed to use a 3D printer, angle grinder and blow torch which made it a little more interesting that normal.
null
Bigger pic
Posted : 19/03/2021 10:00 am
It’s the first build I’ve done where I needed to use a 3D printer, angle grinder and blow torch which made it a little more interesting that normal.
Why?
What size headset, seatpost , seatpost clamp does it take , can't see anything on the PX site
Posted : 19/03/2021 10:26 am
^Nice build using classic Fox 36 Vans, here's mine, Octane One, with a mix of old parts and new where necessary…
2007 Fox 36 Vans reduced to 110mm, Mavic 321 rims on old Hope Pro II’s converted to 10mm bolt in, Avid Juicy 7 rear brake, Easton monkey bars.
Octane
https://flic.kr/p/2kMccu3
I regret selling my DMR trailstar (10 years ago) so I’m now looking to get another pump track/dirt jumper. Im really close to ordering one of these Jack Flash frames, how has your new ride treated you? Reccomend the frame or should i look elsewhere?
Want to buy a trailstar?
Posted : 19/03/2021 10:36 am
@stevie750
The frame specs I got from chatting with one of the planet x support peeps are:
Seatpost: 27.2 mm
Set Clamp: 31.8 mm
Bottom Bracket: 68 mm BSA
Headset: ZS44/ZS56
The 3D printer, angle grinder and blow torch were all used to drop the travel down on the 2006 Fox 36 Vans. I had to cut (angle grinder) and shape (blow torch, then more angle grinder) the spring to the right length to get the travel down to ~100 mm and then 3D print some travel spacers to stop it all extending too much when it tops out. The spring stack now looks like this (next to an original length spring):
Shortened Fox 36 Van Spring Stack
Posted : 19/03/2021 10:45 am
Thanks !
Posted : 19/03/2021 10:58 am
I have one of the original first 100 Trailstar frames that DMR made, keep meaning to build it up into a bike but the parts I need I can’t afford right now.
Posted : 19/03/2021 11:01 am
This forum needs a 'like' button.
Posted : 19/03/2021 11:09 am
@bigginge bike looks really good, what tensioner did you use?
Posted : 19/03/2021 12:18 pm
@tb927 it is an E Thirteen TRS+ dual ring chain guide.
I was planning to use a blackspire stinger as @a11y had on his build here . But, when I was looking for bits CRC had the TRS+ in stock for less than I could find the bottom bracket mounted version of the stinger for, so I went with that instead.
https://www.ethirteen.com/products/trs-plus-dual-chainguide
Posted : 19/03/2021 12:58 pm
nice build bigging, when does the bike first see dirt/skatepark?
Posted : 21/03/2021 9:23 pm
Took it out to the forest today with littleginge with the intention of spending some time on the pump track there. In the end we didn’t make it as far as the pump track as the headset has came loose, possibly with me trying to jump off some tree roots near the car park. I suspect this says more about my building skills/attention to detail than anything on the bike so will get it sorted and try again soon.
Think it’s going to take a little getting used to though after riding much bigger bikes for a while now but seems promising so far. Definitely not the tool for chasing an eager five year old about the forest though; was crying out for a sit down and some gears after 10 minutes of following him, so will be sticking to my normal bikes for anything away from a pump track or jumps.
Posted : 21/03/2021 10:30 pm
Not built mine yet - decided to order some better forks.....
So decided to upgrade the rear axle on the Superstar wheels I had to 10mm bolt through.
Also going single speed 👍
Posted : 21/03/2021 10:41 pm
