Shimano calliper co...
[Closed] Shimano calliper compatibility
[#11649622]
Quick question:
I have a couple of out of warranty, leaking XT 4-pot 8020 callipers. Anyone know for sure if I can just straight swap these out for some Saint callipers? Any gotchas? Same hoses, banjo bolts, etc
Thanks!
Posted : 01/01/2021 10:25 am
Should work fine, I've got some basic deore calipers mated to a set of 105 hydraulic road Brifters
Posted : 01/01/2021 10:30 am
My only concern would be banjo bolt. But this implies you are OK.
Rotorburn
I've gone for 8120 brakes and they do have a different bolt.
Posted : 01/01/2021 11:02 am
Everything should work.
Banjo bolts should be compatible
List is below pic
https://www.sjscycles.co.uk/brakes/shimano-deore-brm555-banjo-bolt-oring-y8h098010/
Posted : 01/01/2021 11:19 am
Great stuff, thanks very much all.
Wasn’t aware of the newer 8120 callipers as it happens... hmm... guessing they will need a new banjo bolt though.
Will probably just stick to saints as i can source cheaply second hand.
Cheers!
Posted : 01/01/2021 1:57 pm
8020 and Saint calipers are identical bar the branding. Same forging.
Posted : 01/01/2021 6:53 pm
