Paint removal from ...
[Closed] Paint removal from BB shell
[#2526203]
I need to remove some paint from the threads of the BB shell (frame been resprayed). What paint remover is safe to use - Nitromors etc? Or are there alternative ways to get paint off? Clearly concerned not to damage thread.
thanks for advice.
Posted : 03/03/2011 5:38 pm
I scraped it out with a pick (dentist's pick) then cleaned out what was left with my homemade BB thread cleaner (an old BB with a load of cuts across the thread, like a tap). Nitromors should do it but I know myself, I'd end up melting the good paint.
Posted : 03/03/2011 5:41 pm
I'd scrape it off myself 🙂 Or get your lbs to clean the threads? can you use an old BB cup ?
Posted : 03/03/2011 5:43 pm
 Olly
wire brush and some elbow grease?
Posted : 03/03/2011 5:44 pm
Had the same issue myself, recently.
Fixed it using a dremel with a wire brush attachment and a steady hand.
Posted : 03/03/2011 6:03 pm
