P7 Questions...
[Closed] P7 Questions...
Bought a 2nd hand Orange (it's actually white) P7 the other week. I love it.
But I'm new to going to trail centres ect. and I've left school to start an apprenticeship therefore have a few monies to spend 😉
My my left Sram X9 shifter has failed, It won't change up or down - what should I replace it with?
The front derailleur is rubbish aswell - I want to change it to a 2x9 derailleur with outer chainring as a bash guard as I will never use all those gears... Is that a good idea?
Thanks for the help 🙂
Posted : 21/09/2015 8:23 pm
Could well be down to knackered cables, especially if the bike has sat around. You can fit new cables and have change from a fiver.
The shifter may well need a blast with WD-40 or similar, followed by a drop of lube in the cable port. As for the front mech, a clean and degrease followed with a dab of lube on the pivots will certainly help. Front mechs are much of a muchness. SLX will see you right, they come with the correct adapters to fit you frame.
My own P7 is 2x9, I run a 36/22 front ring setup with a Blackspire Stinger dual chainguide and a bashring. It's very belt-and-braces, but the drivetrain is very quiet. The Stinger is dirt-cheap at under £25, so it's worthwhile fit.
Posted : 21/09/2015 8:35 pm
