Outer diameter of h...
[Closed] Outer diameter of hyperglide splined freehub?
On the way in this morning, I realised the lockring on the rear hub has come loose. Observing the sprocket merrily meandering from side to side, I realised the chainline would actually be improved if, when I tighten her up again, I pop some form of spacer spokes-side of the sprocket.
Anyone either a) able to suggest some economical products fitting this bill; or b) able to tell me what size the outer diameter of the splines is so I can see if I can fashion something suitable?
Posted : 08/03/2013 3:24 pm
Ht2 bb spacers fit perfectly (but don't use plastic ones).
Posted : 08/03/2013 3:36 pm
interesting. cheers.
Posted : 08/03/2013 3:45 pm
Use and old spacer from between sprokets on a cassette? The plastic bit, custom designed for it. LBS should have a few
Posted : 08/03/2013 3:48 pm
