2 Stages on the go approx 70 miles per week across the two , Du bushes mainly the back one wearing in approx 3/4 months , can a better Du option be obtained , cheers
If you think that side loading is adding to accelerated wear you could try a couple of these.
https://dhsign.it/en/18-fixshox-revo
I'm currently running them in a couple of Levos to stop them from eating shocks.
man, I'm cross - was hoping they'd diversified into pith helmets and safari suits
Du, du bush, du bush mich😁
Sorry, couldn't help myself!
I've found these https://www.tftuned.com/127mm-tf-polymer-eyelet-bushings-bag-of-4/p516
Last longer with my Orange full suspension bikes.
I don't rate DU bushes, always swap out for poly/Igus ones.
The rear eyelet sees a lot of rotation on those, so even without alignment issues, I’d expect them to wear through them relatively quickly.
