Options for fitting...
[Closed] Options for fitting tapered forks to a standard 1 1/8 head tube
 DT78
Found the below thread, a little old, so asking a similar question again. I have a bog standard 1 1/8 headtube with an external hope headset. Is it possible to buy a bottom cup that extends out and allows a fork with a tapered steerer to be fitted?
Increase in lower stack height would be a benefit as I want to slacken the head angle.
http://singletrackworld.com/forum/topic/tapered-forks-in-1-18-head-tube
Posted : 27/05/2013 8:52 pm
If your headtube is a 44mm one, then possibly yes.
If you currently have a zero stack internal 1 1/8 lower bearing on your bike then your chances are good. If it's 1 1/8 with an external bearing, it's not possible.
Posted : 27/05/2013 9:01 pm
New forks or new frame.
Posted : 27/05/2013 9:02 pm
Only option I can think of would be a new csu .
Posted : 27/05/2013 9:05 pm
 DT78
Didn't think it was likely, just exploring options. Dang it.
Posted : 27/05/2013 9:27 pm
