Opinions on Nuke Pr...
[Closed] Opinions on Nuke Proof Generator Hubs.
[#1408689]
Need a new set of wheels but on a budget and have been offered a pair custom built for £140.
Nuke Proof Generator hubs with a good selection of rims and spokes.
Are the hubs any good for XC/trail riding?
Posted : 13/03/2010 6:03 pm
i had a set of these on mavic ex721 rims and they were great.
defo recommend...
better than my mates pro2's even he thought so.
only thing i never really checked was how available were the spares for them.
Posted : 13/03/2010 6:32 pm
nice one brant, i never said there wasnt any or you couldnt get them but just never looked. but good to know there is as i will defo get another set
jamie
Posted : 13/03/2010 6:55 pm
shameless self promotion! can you make me a singlespeed hub please?
Posted : 13/03/2010 6:56 pm
I will say that the OE bearings don't last long and I have had to replace the free hub and pawls but I did buy mine second hand so have no idea how much work they have done although mint when purchased.
Posted : 13/03/2010 7:04 pm
very good.
the rear hub isn't as loud/clicky as a hope pro II, it's the same weight (300gramsish), has been totally reliable for 2 years, and was cheaper than the Hope.
Posted : 13/03/2010 7:07 pm
Will buy a set then!
Posted : 15/03/2010 2:07 pm
I'd budget for new bearings though sharpish if they're anything like mine. The ones in the rear hub lasted 6 month (from brand new) Hotlines sorted me a replacement set at half price, but they've only lasted the same time.
Posted : 15/03/2010 4:26 pm
Got a front one and like it lots...very smooth, pretty light and still ok bearings wise 6months in....not as cool as my old Ti axelled, carbon screw on rear original one though 😀
Posted : 15/03/2010 4:47 pm
front is great, no complaints here.
rear is fine too. however, after an extended period of un-use it seized up. thought i needed new bearings, which ended up being £33 for the set - would have been a lot cheaper, but ONE of the 5 rear bearings is an odd size non of the bearing suppliers i asked could get. arse.
in the end, it turned out that the axle just needed loosening a bit.
my rear sounds a bit rough at the mo, i could probably do with changing the bearings anyway...
Posted : 15/03/2010 5:17 pm
Front is still perfect after 2 years, rear needed new bearings after 4 months
Posted : 16/03/2010 4:42 am
I've had a pair of generator hubs for a couple of years now - bearings front and rear still pretty good.
But rear will need replacing soon - anyone know of some instructions on-line for servicing them?
Posted : 16/03/2010 12:24 pm
 st
I bought a set after Christmas and the freehub was making worrying noises before the end of January. So far it's slipped properly once and makes those worrying crunching noises frequently but I haven't had chance to get back to the shop with it.
It hasn't failed mind you.
Hopefully be easily sorted with a new freehub body.
Posted : 16/03/2010 1:45 pm
harryparabolics,
i took it all apart - was easy enough, just need some allen keys, however, i was unable to remove the bearings... someone said on a previous thread in which i asked, that circlips are used in the hubs, but it wasn't obvious to me.
all my searching online has been fruitless for instructions though.
i imagine they are the same as other hubs, just branded different - may be a case of finding the same design hub and using their instructions, but no idea which hubs to look for.
Posted : 16/03/2010 1:49 pm
