One up 40 tooth cog...
[Closed] One up 40 tooth cog with SLX cassette
HI,
My 40 tooth big back ring arrived today and it turns out I need to butcher my cassette to fit it...
The website says chop the cassette behind the 15 tooth ring and not to worry about knackering the plastic spacer.
I don't understand how I'll put the replacement cog on without a spacer?
I'm probably being dense, but could someone help me out? ๐Ÿ™‚
Thanks
Posted : 01/08/2014 2:39 pm
Is it because you are taking out one of those sprockets and the smaller one that will still be used has the spacer built in?
[url= http://www.oneupcomponents.com/pages/slx-1080 ]http://www.oneupcomponents.com/pages/slx-1080[/url]
BTW I know I'm useless at explaining this. ๐Ÿ˜‰
Posted : 01/08/2014 2:46 pm
http://row-oneup-components.myshopify.com//pages/slx-hg-81-and-xg-1080-cassette-special-instructions
http://row-oneup-components.myshopify.com/pages/instructions
You're cutting between the 15t and 17t cog, and then ditching the 17t, so don't need a spacer because there is one on the 19t cog that will fit between the 19t and 15t.
There should be a spacer with the 40t.
Posted : 01/08/2014 2:52 pm
The 40t has a spacer designed into it.
You can just drill the end of the three pins out.
Posted : 01/08/2014 3:21 pm
Where does the 16 tooth cog go, that came with the 40?
It's go no spacer so would sit flat on the existing next cog up on the cassette....
Posted : 01/08/2014 4:14 pm
Or do I ignore that one?
Posted : 01/08/2014 4:15 pm
Done it!
I still don't quite understand how it worked, but it did ๐Ÿ™‚
Posted : 01/08/2014 4:46 pm
Had planned on getting one of these along with a xt cassette, didnt realise you could use an slx. Any benefits to using xt over slx other than not having to use a saw or drill to split the cassette?
Posted : 01/08/2014 6:47 pm
I bought xt cassettes when I did mine then sold my slx ones,as they come to bits a doddle !..ad they're only &30
Odd quid,the sprockets are v v easy to fit & mech set up is a piss ball !.
I've got a one up 42 on one bike & a hope 40
Ont tother !,both easy peesy ..
Posted : 01/08/2014 8:21 pm
Slx is riveted together xt is individual & takes to bits in sections !.
Posted : 01/08/2014 8:22 pm
