On-One stainless st...
[Closed] On-One stainless steel chainring - not going to work with 10 speed is it?
Just replacing all my drivechain stuff and going to go 1x10. I'd prefer to go for a steel rather than alloy chainring for longevity. Pretty sure I know the answer, but has anyone used the stainless charinring with a 10 speed drivechain? It specifies OK for 9 speed.
I'm going to have to get the ringmaster thick and thin aren't I?
Posted : 26/12/2015 6:49 pm
 cp
It'll be fine.
I even use one on my 1x9 set up with no chain guide... No dropped chains after several races.
Posted : 26/12/2015 7:03 pm
Internal width of 9 spd chains is the same as 10 spd. It's the outer width that changed. It'll work.
Posted : 26/12/2015 7:10 pm
Brilliant jam bo, that's bob on, thanks.
cp - it wasn't the chain security I was concerned with but the thickness of the teeth, good to know though. The teeth are pretty tall, which probably helps the chain stay on.
Posted : 26/12/2015 7:35 pm
Mine worked fine for years. I did try it without a top guide (with a clutch mech, short cage) and it wasn't awful but I wouldn't recommend it.
Posted : 26/12/2015 10:08 pm
I remember hearing that Surly were going to be making a steel Narrow Wide ring, did they ever produce it in the end?
Posted : 27/12/2015 3:16 am
