On-One smoothie low...
[Closed] On-One smoothie lower bearing - what size and where from?
13 Users
Need a lower bearing for my smoothie - shit sealing!
Posted : 14/04/2014 6:31 pm
If it's the 1.5in bottom bearing, Superstar do one for £7.99
if I recall correctly it's the 45x45 degree one
http://superstar.tibolts.co.uk/index.php?cPath=61
Posted : 14/04/2014 6:46 pm
Just removed the fork - which took some persuasion. Bike has been built for 16 weeks at most. Lower bearing is rusted into the cup, balls are rattling around in what is left of the cage. Inner face is stuck on the crown race! WTF have i paid for - this is a bag of shite - sealing must be tracing paper at best!
Posted : 14/04/2014 7:36 pm
I guess warranty is out of the question as bearings are "wear" items but there has to be a "not fit for purpose" option.
Posted : 14/04/2014 7:40 pm
Will give them a ring in the morning - it's not even a cheap headset at £40 really
Posted : 14/04/2014 7:41 pm
Crap i've just bought one of these to fit to my straight steerer in tapered headtube. This doesn't bode well at all! Also did you have a gap between the crown and the bottom cup? I can't get mine to seat onto the crown even with proper pipe for fitting..
Posted : 14/04/2014 7:45 pm
yes to tiny gap 0.5mm ish
Posted : 14/04/2014 7:48 pm
If unhappy please return for full refund.
Pop my name on it.
Sorry.
Posted : 14/04/2014 7:54 pm
I will do my best to get it out and send it back - where do i send it to?
Posted : 14/04/2014 8:01 pm
The one in my fatty went the same way in about the same time. I dropped the forks out to clean and grease and the whole lot came apart, bearings all over the place.
I called on-one and just got told to but another lower race. I went FSA instead.
Posted : 14/04/2014 8:05 pm
I sent mine back. Its on here somewhere. Pile of poo. They sent it back to me saying it was wear and tear after a dozen rides. I bought Mr Torchy Torchy bearings and have much better sealing. Smoothie bearings with teabag tm sealed bearings.
Posted : 14/04/2014 8:06 pm
I am not convinced the inner race will come out of the cup to put new bearings in tbh
Posted : 14/04/2014 8:08 pm
Did you grease the bearings up n all? Maybe a stupid question but I want to rule out any potential for user error! I certainly applied a liberal amount of grease.
Posted : 14/04/2014 8:16 pm
yup as always
Returns details here - http://www.on-one.co.uk/help/returns-and-refunds
Posted : 14/04/2014 8:25 pm
mines also just gone but to give a bit of balance i've had it for 16 months and used it for commuting every day in rain and mud as well as big rides at the weekends. i can't complain really!
Posted : 14/04/2014 8:27 pm
I never got the option of returning when I contacted on one. Just 'buy another here's the part number'
What remained of the lower bearing was stuck in my frame too, I had to get a long screwdriver and go in from the top and tap it out. A bit cowboy but it did the trick.
Posted : 14/04/2014 8:29 pm
yup as always
balls
Posted : 14/04/2014 8:41 pm
is the superstar bearing better sealed or is it a problem with the cups
Posted : 15/04/2014 5:41 am
Thread hijack... Twoniner, which FSA one did you fit to your (now mine) fatty? It appears to have gone the same way as the on-one - don't suppose you know the angles and sizing do you?
Posted : 15/04/2014 7:13 am
 nbt
[quote=speedstar a dit]Did you grease the bearings up n all? Maybe a stupid question but I want to rule out any potential for user error! I certainly applied a liberal amount of grease.
first: I applaud Brant's customer service on this thread,
second: why the hell should you have to add grease to a SEALED bearing when BRAND NEW. I'm not an engineer, please enlighten me
Posted : 15/04/2014 8:17 am
As a matter of course I never assemble anything dry unless it's into carbon. With my Fargo there's a hole through the headtube inside where the gusset is welded between head & downtube. Lovely area for water to flush through the headset the wrong way. The grease isn't for the bearings as such as just where components sit in the same place for any length of time.
Posted : 15/04/2014 8:42 am
because the grease acts as an additional sealing medium and helps keep muck out, but this isn't indicated in any literature so I don't blame anyone for not trying it.
I think I might be needing a new lower bearing for my 1 1/8 inch smoothie regular soon as well.
So, did anyone discover what the code for that bearing would be, please?
I agree with Brant on the grease question, though. So long as the parts aren't minute and so impaired by loads of sticky grease (like hope freehub pawls and springs), then packing in a load of grease just seems like common sense to me. If grease oozes out when you press two parts together, then that means there is no room for that grease. It follows that there probably isn't any room for anything else as a result (water and grit for example).
Obviously grease degrades over time, and you might get a bit coming out as time goes by, but it's much better than having to buy expensive components more often than absolutely necessary.
Anyway I digress. If anyone does know the code for a lower bearing of a smoothie regular, please can then post it here?
Posted : 15/04/2014 5:33 pm
Just email me Danny with your last sales order number. I will send you a new one.
Posted : 15/04/2014 6:47 pm
Pretty sure I had this one-[url= http://superstar.tibolts.co.uk/product_info.php?cPath=61&products_id=439 ] [/url]
The fitted bearings must have gone downhill because the one I got lasted two years before replacing
Posted : 15/04/2014 6:52 pm
Cheers, Brant.
Email on the way!
Posted : 15/04/2014 7:58 pm
Can you send me one for my 1.5" lower bearing please
Posted : 15/04/2014 9:25 pm
