On one scandal - 18...
[Closed] On one scandal - 18 or 20"?
I'm 6' 1" and currently ride a 19" kona with 100mm travel and 80mm stem...
Posted : 19/01/2011 12:08 am
I think you'll be fine with an 18"
Posted : 19/01/2011 12:25 am
I think you'll need a 20". I'm 5'11" & think my 18" is a bit small so I'm looking for a 20" to try.
I've just sold a large Singular Swift as I found the front end too high (new models have addressed this with a shorter fork) but its the same effective top tube as 20" & I found the Swift OK with an in line post & 100mm stem.
On the 18" Scandal with the 100mm stem I need the saddle a long way back on a slight lay back post but with a 400mm long post its a long way out although still below the top tube/seat tube lower weld.
Just ordered a 400mm long post with lots of layback to give it another go but think a 20" with in line & may be 90mm stem would be spot on.
So for you I would think you need a 20".
Posted : 19/01/2011 7:52 am
Definitely a 20" - I'm just under 6ft with 33" leg - unless you like running loads of post that is.
Posted : 19/01/2011 7:58 am
I'm 6'1 with 34" inside leg and ride an 18" 29er with lots of post and a riser stem. Absolutely love it. Be interested to try a 20" for comparisons sake but no intention to change
Posted : 19/01/2011 8:15 am
Brant used to run an 18" with a 400mm twelfty seat post and 100mm stem on and he's 6 2" If I recall correctly when he had his sizing info on the old OO website.
My mate's the same height and runs an 18" inbred set up the same way and loves it.
Posted : 19/01/2011 8:30 am
I ride a 456 in 18" and i'm 6' 2" and it rocks! not sure about the diferences in geometry but i'd go 18" if it were me.
Give On One a call and get their advice
Posted : 19/01/2011 8:38 am
I'm 6'1" and ride an 18" Inbred (which is the same geometry as the ScandAl rather than the 456 version). It's much longer than my 18" Kona with same 80mm stem and it works for me! I think I'd find the 20" frame too long. Yes there will be plenty of seat post showing - 2" more than if you chose the 20" frame ๐Ÿ˜‰
Where are you? There must be someone local with a bike you can have a play on!
Posted : 19/01/2011 9:13 am
That's a sound idea simon1975 - I'm in Notts, if anyone knows the Hemlock Stone...
be good to try before I buy and mess my back up again...
Posted : 19/01/2011 10:57 am
 Pogo
I'm 6'1" 34" leg and have a 20" Inbred, with inline seatpost and it's about spot on, just feels quite big. I'd get an 18" if I were you.
Posted : 19/01/2011 11:24 am
I am 6ft and I have an 18" Scandal with 100m stem and a 19.5" Inbred with 80mm stem (both 29ers), and they both feel a good size.
Posted : 19/01/2011 11:30 am
6'1" 34" leg. have two 18" inbreds. Both feel fine if i am changing position a lot and out of the saddle. But didn't feel too comfy when just cycling in a more static position. Just ordered a 20" frame and to be honest, it looks rather big =/ Haven't build it up yet tho.
Posted : 19/01/2011 12:45 pm
Yes I'm in Nottingham. I rode past Hemlock Stone last night ๐Ÿ˜‰
Come and see me in Mapperley some time - we could meet at Woodthorpe Park perhaps for a quick play on an evening - would you prefer fixed or freewheel? My email's in my profile!
Posted : 19/01/2011 2:47 pm
