I bought a 2nd-hand OnOne a few months ago, but I'm not sure whether it's a standard InBred or a 456. How do I tell?
It's a pale green colour frame, not far off the Bianchi colour, if that's any help.
A top tube thats as wide as the down-tube is the biggest give-away.
Sounds like a 456 in that green
Sounds like a 456 in "that green".
I thought the later inbreds had the fatter top tube as well?
456s have the cables routed on TOP of the top tube. Other Inbreds have it underneath.
Put a 6 inch fork in it and see if it folds in half.
Thank you, all.
AS it's that green with top-routed cables and top & down tubes of similar diameter, it must be a 456.
Hooray.
standard inbred here....with the cables routed on top of the top tube...
[i]top & down tubes of similar diameter[/i]
Also the top-tube has a similar diameter to the short upper tube of the seatstay assembly
PMSL @ Northwind!!
that green is my facourite ever on-one colour.
