On One Fatty riders...
[Closed] On One Fatty riders - Alpkit advice please
I want to buy a Possum framebag as a present - what size Possum for a medium Fatty? I recall seeing a picture on here somewhere but I've searched without joy. Ta.
Posted : 01/04/2015 7:27 am
Not sure they are a good fit tbh, especially if you want to use the bottle cage.
beerbabe.co.UK does a full frame bag, not sure you want to go the whole hog though
Posted : 01/04/2015 7:55 am
I don't have the Possum but do have the Wildcat version, can't remember its name now - Ocelot?, anyway the sizing instructions say to measure the underside of the top tube and chose the bag size accordingly.
Doing this I ended up with a size too large - I think I needed to measure the top tube from seatpost to the point where the top tube and down tube were about 2 or 3 cm apart rather than to the head tube (the top and down tubes touch at this point on my frame).
Not a precise answer but should let you give some idea as to what size.
Posted : 01/04/2015 8:29 am
I went for their standard basic frame bag, for £65 you can completely fill the front triangle. Go for the ladder stitching so you can put the velcro where ever you want.
Posted : 01/04/2015 11:03 am
Deleted while I try and make the link work!
Posted : 01/04/2015 11:07 am
Hopefully that works.....
Posted : 01/04/2015 11:17 am
That's great Johnny - what size standard bag is that?
Posted : 01/04/2015 11:57 am
It's a large frame. When I said standard bag, I meant it was a standard Alpkit stingray. The base model with one zip is £65. You can get a fatbike version that tapers out at the headtube end so increase volume at the expense of potentially getting in the way of your knees when pedalling out of the saddle. I stuck to the normal one as the fatty frame wouldn't let you gain much from a wider from bag. I chose the max standard width and used the cardboard template method to get the measurements to them. It was with me in a couple of days!
Pleased to see AK have also started doing Airlock bags in Jaffa orange too. 🙂
Posted : 02/04/2015 6:51 am
