Any ideas how this would handle on a normal 29er (Inbred) with a 29" wheel in? It has 55mm offset instead of 45mm on the others but I'm not sure what effect this will have?
I assume it take any 135mm rear hub?
they're selling their fat not fat wheelset (fatty hubs with 29er rims) for everythign uo to a 2.4 29er chunky monkey so clearance must be ok. I'd check a-c to make sure it's not hugely shorter, though.
it's the same length 470mm just 10mm more offset, not so much worried about tyre clearance just effect on handling
I've got a 29" knard waiting to go in one.....only they sold out of the buggering things before I could buy one ๐ฟ
more offset will quicken up the steering - similar to a steeper head angle.
Possibly worth a wee read:
Spacing is 135mm but disc mount position is front hub standard.
Rear discs hubs will work but either disc or caliper needs spacing over.
(will a knard fit?)
Can anyone give me the dims for this Knard thing?
Rolling radius
Width
Radius at max width.
@brant Surly tyre geo [url= http://surlybikes.com//uploads/downloads/SURLY_Tire_Geometries.pdf ]here[/url]
Am I imagining things or did I see something recently about you planning a carbon 29er in a Yelli Screamyish style?
That would be nice.
That would be nice.
Working on a Fireline-esque carbon model yes.
Ooh Hello ...that's got me interested ...swap-able dropouts as well??
On-One has a carbon fork coming for the Fatty. I'd bet that there will be a few of the original steel forks for sale when the carbon ones go up for sale!
[i]I'd bet that there will be a few of the original steel forks for sale when the carbon ones go up for sale! [/i]
they've pretty much sold out of the first batch of carbon after putting them online yesterday ๐
Miffed, saw email for Fatty carbon but in hospital waiting for new miniAkira to be discharged so missed out. I'm guessing they didn't keep any back for exceptional circumstances.
more in at the end of Feb according to their twitter feed.
Email notifications set up for both colours, hoping fir stoke photos of both before then so I can decide which to go for.
Knards will fit fine in steel fatty fork. Having played with custom forks and offsets for years in 29ers the 55mm offset wil play best with a 68-70 head angle. Steeper and it will be a twitchy little blighter thand will have a tendency to tuck under on tight corners. Used 55 ofset jones truss on a proto scandal and it was ace. Stoner now has it on a ti 28er on one and rates it as well so should be good with a fatty fork n inbred. I would run it half fat though as its ace!
need photos of the carbon fork mounted into a fatty, hopefully it looks sweet and all the lines erm line up! Was hoping for a tapered steerer to dump the pants Smoothie 1 1/8th lower headset adapter.
http://www.on-one.co.uk/i/q/FOOOCFAT/on-one-carbon-fatty-fork
Will have pics of the black mounted into my satin black oo fatty on monday. Forks are lush although clearance is a wee bit tight with a bud..would be fine with a nate
tazz.
Can you do some pictures of the clearance with a Bud mounted on a Rolling D please?
Yep will do tomorrow for you stu...can you mail me re your sheepie post as well please sexypants x
Sorry mate i forgot about that taty old cheapo post that i was going to send down the tip. ๐ณ
Pics then tazz?
Ta.
They 80mm rims?
70's
Could you measure the tyre at the widest point for me please?
