Old racer to single...
[Closed] Old racer to singlespeed
I'm converting an pretty rubbish racer into a singlespeed.
Is it as simple as the following:
Take off cassette
Fit single speed cog and use spacer kit to fill gap.
Take 1 x cog off my chainset
Buy a new chain
Do I need a chain tensioner in place of the rear mech or can I just take the rear mech off?
I don't understand all this talk about the verticle dropouts? Is this a problem?
Any advice would be great!
Posted : 13/10/2011 11:34 am
if it's got vertical dropouts, you will be lucky to get the chain length right so you have decent tension (so it doesn't come off) - i.e. you will probably need a tensioner.
if the dropouts slope, you're fine
you don't necessarily need a new chain
Posted : 13/10/2011 11:37 am
Depends if your bike has a feewheel or a freehub and cassette. If its a free wheel it will be pretty hard to single speed without a new wheel/hub.
This is a verticle drop out which means you cannot addjust chain tension.
This is a horizontal drop out where you can adjust the chain tension.
another option is track drop outs which give you loads of adjustment.
Posted : 13/10/2011 11:38 am
The late, great Sheldon Brown is your friend:
http://sheldonbrown.com/singlespeed.html
It might be that simple, but depends what kind of dropouts your frame has ( http://sheldonbrown.com/singlespeed.html#vertical), whether it's a cassette hub or screw-on freewheel etc
Posted : 13/10/2011 11:39 am
check the old bike hasn't got a screw on freewheel/cassette combined thingy rather than a modern freehub - you can't just swap to singlecog then.
that red one isn't a vertical dropout.. though it still doesn't exactly give much room to move! you might get away with that.
Posted : 13/10/2011 11:40 am
Thanks - I'll check the dropouts
Silly question but how do I now if I have a freewheel, hub or cassette.
The bike does have a 8 speed cassette so I assume its a cassette?
Posted : 13/10/2011 11:41 am
Sounds like a cassette - does it have a lock ring?
Posted : 13/10/2011 11:42 am
I did a very cheap singlespeed last year, left the casette on and picked the gear and shortened the chain to suit. Make sure though that the chainline is not too extreme.
Posted : 13/10/2011 11:45 am
Yes it does have a lock ring.
So the dropouts allow you to tension the chain correctly. I think mine are vertical.
Posted : 13/10/2011 11:46 am
Was thinking about that higthepig but thought it be best to get off cassette and lose the weight.
Posted : 13/10/2011 11:47 am
you _can_ try for a "magic gear ratio" (and i even think there are things online that work it out for you) but it's a bit of an arse and any "stretch" will make itself quickly known
Posted : 13/10/2011 11:52 am
I did to work out what was the best ratio before I pulled off the casette and replaced with a single sprocket, took me about 3 months to work out what was best though!
Thanks - will give it a go this weekend and see what happens...
Posted : 13/10/2011 12:05 pm
