Oil coming out the ...
[Closed] Oil coming out the top of my pikes?
 krag
I've noticed there's oil leaking out of the blue lock out/damping/motion gate area. It's not loads but it's more than a residual film of oil.
Any ideas what it could be? They're 08 coil 454s.
Posted : 18/05/2010 11:30 pm
This is a very common issue with Rockshox forks, a seal in the compression assembly can leak occasionally.
It can be a DIY fix, but for best results send them to TF Tuned who'll modify the seal and the problem won't reoccur.
Posted : 18/05/2010 11:32 pm
 duir
Yes! Your MC unit and associated seal has failed a very common issue. Mine did that. I sent them back to RS under warranty (24 months I believe) and they took a few weeks to fix them. New MC unit and better seals. No issues since. If you can't wait send them to TF. If you are patient back to RS.
Posted : 18/05/2010 11:33 pm
 krag
Cor that was quick ๐Ÿ™‚
Cheers both, I have a friend who's pretty handy and services all our clubs forks so I'll get hold of the seal and sort it.
Posted : 18/05/2010 11:38 pm
You can open it up yourself. I did it and took some pics here: [url= http://www.basquemtb.com/repair-leaking-pike-motion-control/ ]How I Fixed My Leaking Pikes[/url]. Having said that they started leaking again after about 3-4months. I think that the seal that I repaired can be upgraded and that TF use a slightly thicker seal which is less likely to leak.
Posted : 19/05/2010 7:26 am
call BP
Posted : 19/05/2010 7:40 am
psml..BP) lol ๐Ÿ˜†
Posted : 19/05/2010 7:43 am
 krag
Doug: Thanks that's really useful, was about to order the MC kit off TF tuned but if you were able to fix yours I'll have a go first ๐Ÿ™‚
Posted : 19/05/2010 2:17 pm
