Introducing Flat Mount for road bikes.
Key advantages over current available mountain bike disc mount structures are:
A cleaner, integrated construction with the frame (no visible mounting bolts)
A more direct connection to the frame and better alignment (eliminates stacking
adapters)
Easier tool access for disc caliper adjustment (even inside rear triangle)
Backwards compatibility with mountain bike style post mount calipers (with an adapter)
[i]Shimano launch a new disc brake [b]non-[/b]standard[/i]
ftfy.
That looks like the old Hayes mount used by Gary Fisher and Trek back in the day.
nice to see
Just means another adaptor?
Sexy though innit
We fell over this in a tech pack a few months ago.
Had us scratching our heads for a bit.
no spoons 🙁
Sexy though innit
I know you've got a lot of free time at the moment, but not everything you find on the Internet has to be sexy. 😉 Particularly a brake mount.
Brant, not my first thought and as I look at it again I still don't get it.
Surely anything over a 140 rotor would require an adaptor though?
But does fit its intended use for road bikes as total weight saved on frame and adaptors should not be insignificant...
Here we go again then...
Does it integrate nicely with hidden hoses/cabling?
You know just to make something as simple as fitting a rear brake inordinately fiddly, time consuming and frustrating?
Just you lot wait, first awsome new mounts, then it'll be "Blended" Aero style caliper bodies (Front and rear specific of course), then they'll make them out of Carbon (what else) and before you know it the roadies will have out done us MTBist by having barely visible, feather weight disc brakes that cost £500 an end, and you absolutely must have if you plan on entering a sportive... and then they'll turn up on MTBs.
Its a brave new world folks!
But I'd be holding off buying a new road bike for a good couple of years yet...
The great thing about standards, it there are so many to choose from.
It's clearly going to be expensive, needing special "invisible" mounting bolts (which no doubt you will loose when you put them down somewhere mid pad change......)
Seriously, unless i'm missing something i can't actually see any real advantage? Other than being different?
Is the advantage (for shimano) that a frame designed for thus style will only be able to use shimano brakes?
I reckon its primarily an aesthetic thing, Raodies like, sleek sexy lines they don't like bumpy items sticking out like bolt heads or messy cables/hoses cluttering up the exterior of their bicycle being all accessible...
Hide it. Hide it all!
The more like an industrial designer's concept model you can make a production bicycle look the more they will love it...
hmm could be, would be a subtle way to sneak forward disc compatibility into frame/forks too.I reckon its primarily an aesthetic thing, Raodies like, sleek sexy lines
[s]I assume there is enough distance on the slider to manage atleast 2 different rotor sizes, 140&160? can't see many roadies going for a 200/180 F/R setup. that will mean no need for an adaptor, so a minor improvement there but it's a sledgehammer walnut scenario.[/s]Surely anything over a 140 rotor would require an adaptor though?
scratch that, I thought the purple bit in that second pic was a slide mount of some sort, on a seccond look I think it's just a mount so probably means a specific calliper for a given rotor size, a backward(ish*) step to IS days then 👿
*PM and adaptors are better for compatibility and readjusting your brake while out on the trail (usually badly) but atleast with IS your callipers were guaranteed to be aligned with your rotors.
[i]Surely anything over a 140 rotor would require an adaptor though?[/i]
We'll be back to the old rotor size specific calipers before you know it 🙂
This all assumes they go for the same nice round numbers,
136mm Rotor sir?
Oh its for the front sorry, you'll be needing 157.5mm and probably a new front hub with a marginally different spline pattern...
Not that I'm a cynic...
tomcanbefound - Member
Yep - but it's backwards compatible with existing calipers and rotors if you use an adapter.
So as new standards go, it's OK by me - it's the ones that bake all your old kit incompatible that piss me off.
