AS ABOVE I THINK I HAVE JUST REALISED THAT THE KORE T RAIL SADDLE I BOUGHT WILL ONLY WORK WITH THE T RAIL SEATPOST?
IF SO WHERE DO I GET ONE?
DOES ANYONE MAKE ONE?
I HAVE A STANDARD ON ONE TWELFTY POST, WILL IT FIT?
No idea ,well done on the caps
skool holidayz allreddy?
[b]COULD YOU TYPE A LITTLE LOUDER AS I'M MIDDLE-AGED AND MISSED SOME OF THE OP[/b]
Edit and I can't spell!
Pardon ?
something like [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=62299 ]this[/url]?
I've also read somewhere that you can get an adapter for a standard seatpost to make it fit.
sorry i will whisper for the old farts out there
yes like that wacko, the saddle is amazing, hope i can find an adaptor for it, or one of the posts
There's an I beam adapter on ebay for £5.00 at the moment. Not mine by the way. I use Kore I Beam posts and saddles on two of my bikes at the moment and like them a lot as it is so much easier to change and adjust saddles with them. Note that the adapter will add an inch or so to the saddle height.
Try looking for a I beam post. its a SDG design and kore just make a version.
unless you want to use a dropper post then yes some one does make one, but i can't remember who at the moment.
Iirc, they're fully compatible with SDG's I-beam posts.
Edit; Jesus, beaten to it as I corrected my spelling 😆
gravity dropper and KS make i beam droppers if thats what you are after
ok thats cool ill look at the i beam stuff.
that adaptor for £5 only converts standard saddles to fit an i beam post, i need it the other way round.
Oops so it does, sorry!
