Offset bushing inst...
[Closed] Offset bushing installation
Hi
Got some offset bushings from Burgtec.
Its come with the bushings, a plastic cover type thing and 4 o rings. does anyone know where the o rings go? The plastic cover thing does not fit on my shock (fox float RL)
or will it be ok without the o rings?
Posted : 13/08/2014 11:05 am
Got a pic of the bits? Normal bush kits have the main mount (with the offset hole in), a DU (plasticy) bush, square profile o-rings and aluminium spacers.
Posted : 13/08/2014 11:21 am
Ah, ive just realised the reason why the du bushes wont fit is because the old ones are still in the shock!
Anyway here is a pic of the items, as im still not sure where the o rings go.
Thanks!
Posted : 13/08/2014 11:36 am
Stick an O-ring on the offset wossamajig, put it through your shock bushing (Fit new bushing by pushing out the old with the new), fit the next O-ring, then the aluminium spacer, and that's it.
Posted : 13/08/2014 11:42 am
When the new bush is fitted:
Slide one o-ring onto the silver part, up to the shoulder
slide the silver part (and o-ring) through the bush in shock
Put other o-ring onto silver piece
put metal ring (centre piece in your pic) onto the end of the silver piece you've just pushed through the shock.
On your kit the 'axle pin' and 1 of the 'spacers' in my pic are 1 piece.
Posted : 13/08/2014 11:44 am
I cant get the old bushings out at the moment. is it ok I leave the old ones in while I take it for a test ride tonight? then change them over tomorrow or something?
Posted : 13/08/2014 12:10 pm
Depends on how worn the old ones are. Should be fine if there's no slop or play in them.
Posted : 13/08/2014 12:12 pm
Them seem fine. Thanks guys. I have to say visibly I cant tell a difference, and the head angle app on my phone hasn't changed much, if at all. Guess the proof will be in the riding?
Posted : 13/08/2014 12:17 pm
How much are they off-set? The ones I made for my Intense (2.5mm offset) altered the head angle by about 1.5 degrees..
Posted : 13/08/2014 12:25 pm
They are Burgtec Ti ones, not sure but I think 3mm offset? Im not sure though, Supposed to be 1 degree change. Having said that, looking at the shock length its definately shorter so I guess they have worked.
I know the phone apps aren't exactly reliable?
Posted : 13/08/2014 12:39 pm
