Odd reverb issue, p...
[Closed] Odd reverb issue, please save my sanity
Odd because I've not had this before and google is letting me down on this, so I'm turning to the collective singletrack wisdom....
Went to do a bleed on a 1st gen reverb stealth, did the usual process of: raise front end of bike; raise seatpost to full extension; rotate mount round so screw was at the high point; wind the speed out to slow; bleed screw out of remote and pop a 1/3rd filled syringe in there; same at the post end with 2/3rds full then the in-out/push-pull of bleeding the system and took everything back out. Nothing unusual so far, but when I go to press the remote it is absolutely solid now. Maybe 1mm of movement.
I've retried the process a couple of times now and done the remote bleed too, but nothings made a difference and it's fairly rapidly making me want to throw the damn thing out the window - so has anybody hit this before? How am I screwing this up ?
Posted : 20/12/2014 1:06 am
Empty syringe at the post.2/3,s at the remote then bleed.
Follow this. ๐Ÿ˜‰
[url=
Posted : 20/12/2014 1:12 am
Wouldn't make any difference as it's the same logic. And I've just tried that and sure enough, it didn't.
Posted : 20/12/2014 1:45 am
I would place money on a kink in the hose inside the frame
Posted : 20/12/2014 8:34 am
This happened to me before and it was indeed a kink in the hose inside the frame. It's a bugger because the hose now has a permanent slightly bent bit which makes it not quite as smooth as it should be.
Posted : 20/12/2014 9:26 am
Absolutely bang on, it's a kink.
Downside is that the bleed hasn't fixed the slight suspension the post currently is giving me, so it's a warranty job anyway as the air & oil must be mixing.
Thank you both though.
Posted : 20/12/2014 5:22 pm
