O rings - where to ...
[Closed] O rings - where to buy
Just mangled the o ring on a Juicy 5 lever bleed port, where can I buy a new one?
There is one in the Avid service kit, but tht is £35 and seems a lot for an o ring. Who sells these things?
Posted : 05/09/2011 10:22 am
motor factors ?
Posted : 05/09/2011 10:24 am
Seal supplier such as Supaseal or even ebay for small quantities as suppliers will want to sell you 100 as it makes no sense to sell 1 or 2 - just measure your old one.
Posted : 05/09/2011 10:35 am
simplybearings.co.uk
Posted : 05/09/2011 11:25 am
go to your local SRAM dealer, they should have a little box with all avid spares in, worked for me!! - may have to pay a few quid though
Posted : 05/09/2011 11:33 am
These o-rings are dot fluid specfic and it may be hard to get them from a o-ring supplier in small numbers you may have to ring around the shops to find one. They are not always used when using the service kit.
Posted : 05/09/2011 11:36 am
AS I SAID BEFORE GO TO YOUR LOCAL SRAM DEALER, HE WILL HAVE A LITTLE AVID SPARES BOX
Posted : 05/09/2011 11:49 am
if you get nowehere re above, due to an ebay buying accident I'm the proud owner of a large number of different sized small orings - let me know inner diameter and thickness (and outer diam if you can), and I'll see if I have one that might fit
MIP (*need to read then edit)
Posted : 05/09/2011 12:42 pm
Sorted, new screw with washer 99p from bikegoo 🙂
Posted : 05/09/2011 2:35 pm
