Nuke Proof Ard inse...
[Closed] Nuke Proof Ard insert rattling
Hi
I'm running the above tyre insert in my rear wheel and it has started to rattle. I'm sure it was ok when I first fitted it around 6 weeks ago, any tips?
Posted : 28/05/2021 9:04 am
Only suggestion I have is cut it, shorten it and re fix with a zip tie so it isn’t loose and rattling around.  When you replace it get something like a Rimpact Pro instead
Posted : 28/05/2021 9:13 am
BTW this review is pretty good, at least in so far as it reflects my feelings after trying a couple of inserts
https://www.pinkbike.com/news/review-6-best-tire-inserts-2021-ridden-rated.html
Though I have returned to going insertless as I found inserts messed with my sealant
Posted : 28/05/2021 9:18 am
Apparently the newer versions of ARD are a bit tighter so shouldn't rattle but you either live with it or cut and zip tie, maybe it could be cut and glued....
Mine is noticeably loose when I remove the tyre but I don't get any rattle whilst riding so not sure what causes it exactly
Posted : 28/05/2021 9:19 am
Here you go, CRC website has a guide to tightening the fit, it's a download able pdf. Did mine about 6 months ago using this technique and it's been bang on since.
Posted : 28/05/2021 10:40 am
 Robz
Yeah mine started doing this too so got rid of them. I don't bother with inserts now and don't miss them.
Posted : 28/05/2021 10:46 am
Thanks Guys, just cut and zip tied it. 5 minute job... sorted! 🙂
Posted : 28/05/2021 11:14 am
 DrP
I ahd this.
It drove me MAD trying to figure out WTF was rattling!!!!!
Honetly, once i realised it was the insert, I felt like a new man!!!!
Anyway..binned them... don't miss them..
DrP
Posted : 28/05/2021 11:56 am
