New XT disc brakes ...
[Closed] New XT disc brakes - help, sticky lever!
Hi
I've just bought some XT M785 brakes from Rose. I swapped over the levers yesterday without any problems (pleased with myself, first time playing with hydraulic brakes on a bike :-)).
However, the rear brake lever is slightly 'sticky' on return travel when compared to the front lever. I've read about sticking pistons being a possible cause, but would that be a problem on new brakes?
Has anyone had similar issues?
Thanks
Rusty
Posted : 13/01/2013 8:08 am
I had this problem after a crash. took me a while but I eventually realised that the lever had rotated and the bottom of the lever pivot was pressing on the gear lever. When I moved it back it was fine. If you are very lucky that might be the problem.
I've had the same problem since and it wasn't related to the lever position, I put some wd40 on the pivot and worked the lever for 5 mins and it was ok then, I think I might have been a bit careless with a jet wash on that occastion. Good luck!
Posted : 13/01/2013 9:43 am
wd40
Posted : 13/01/2013 9:44 am
Thanks for the responses.
I've just fitted the brakes and they've only seen some action in the street when I've bedded in the pads. No crashes yet! ๐Ÿ™‚
So squirt some WD40 on the pivot and where the 'wave' cam is? I presume the seals won't be affected?
Posted : 13/01/2013 10:16 am
