I have a 2011 giant anthem x4,and want to upgrade the current
wheels!I'm a bit confused on axle size i.e 15mm front? and rear sizes!
The wheel size is 26inch but the rest of the dimensions i've no clue!
Would just phone dealers,but working out of country,so thought i'd
stick it on the forum for the advice!
Thanks for any help
The rear is standard quick release.
As for the front there are three options. If you use the same type of lever ie qr then that's what you want. Otherwise it is probably 15mm with a removable axel.
Thanks,shortcut!
I've been looking at the crank bros cobalt 3 wheels,
They are 15mm front,12mm x 142 rear?
Unsure if these will fit my anthem?
Both front and back wheel on my bike are quick release
and the original mavic wheels with shimano hums.
your rear is 135mm x 10mm, front is either a 15mm axle or 9mm from a quick google - sounds like latter from your last post.
