xt chainring bolts ...
[Closed] xt chainring bolts for us on a singlering?
[#4088945]
can i use my xt m780 10speed crank arm bolts on a single ring 32 tooth setup up front?
will they be to wide to fit through my hope 32 singlering? i know you can use specific bolts for singlering, but the lbs gave me some of the longer backed plates, so these would screw in further and lock?
only problem i can see with that is the actual xt bolts may be wider than the hope ring?
Posted : 21/06/2012 10:44 am
anybody please? so i can pop out at lunch if need be?
Posted : 21/06/2012 11:26 am
Generally no; the 'nuts' will be too long. Get some KCNC ones from ebay.
Posted : 21/06/2012 11:37 am
They will most likely be too long, however in the past I've cut down the 'female' part of the bolt by a few mm and they worked fine. It just requires a decent hacksaw blade and something to hold the bolt (in my case a bench vice).
Posted : 21/06/2012 11:42 am
thanks guys - think ill get some specific single ring ones at lunch then just in case!
Posted : 21/06/2012 11:43 am
they are defo too long.
Posted : 21/06/2012 11:53 am
