New wheels. New ce...
[Closed] New wheels. New centrelock rotors or adapters?
 benz
Some new wheels for bike which are centrelock.
Already have a selection of 6 bolt rotors inc Hope floating.
So....buy some centrelock to 6 bolt adapters or get new centrelock rotors?
Do ice-tec make a difference...really?
Thanks
Posted : 21/06/2015 10:51 am
center lock means you need 2 tools with you if you travel and remove rotors, I have a T tool on my multi tool. So for me 6 bolt is the winner.
Posted : 21/06/2015 10:54 am
uses the same as the cassette lock ring ... never had one loosen on
the trail ...
centre lock for me.
Posted : 21/06/2015 10:59 am
both the same?
seen both versions on one bike before (and having just checked the XC bike it uses both)
The travel point was more about packing for flying.
Posted : 21/06/2015 11:03 am
DT Swiss adapters.
Posted : 21/06/2015 11:09 am
The second tool in mikes pics are for hubs with 15mm axles as they need a larger lockring to clear the enlarged axle.
Standard QR axles use a standard cassette locking tool.
Although that 2nd pic shows a XTR centrelock rotor(which I have 2 of) and mine came with a normal lockring like in the 1st pic.
Posted : 21/06/2015 11:11 am
Mike I'm puzzled by your second picture. Sure a 15mm or 20mm thru hub needs the lockring which uses the Shimano BB tool, but that picture shows a standard QR axle which [i]should[/i] use the lockring in the upper picture.
Anyway, you're right, if you've got a 15mm front and QR rear then you need both tools, but they are commonly available ones (cassette tool and BB tool) so I've never had a problem when travelling.
I also think Centrelock is an inherently superior system, so if you've got the hubs for it, use it would be my recommendation!
Posted : 21/06/2015 11:12 am
15mm front is the External one, 142x12 is the internal one, seen it on plenty of wheels including the pair in my spare room. For me it just means 2 more tools that I have to pack in my flight bag in a 23kg limit.
Posted : 21/06/2015 11:18 am
Yes I know, I have two pairs of centrelock wheels, but your second picture shows the external one on a QR axle which is wrong. That's why I asked the question...
Posted : 21/06/2015 11:21 am
Centre lock every time.
For the very few times I need to remove/re-fit rotors it's way quicker. Know what you mean about extra tools, but they don't weigh much.
6 bolt are a pain in the hoop - take way longer to fit/remove and tend to remove some knuckle skin while doing so.
Got a 50:50 mix of CL and 6B and I much prefer CL.
Posted : 21/06/2015 11:23 am
just the pic from park to show it's 2 tools needed to swap rotors. For the upside it's a reasonable downside.
Posted : 21/06/2015 11:24 am
Oh OK just a pic from the interweb. Park should know better tho... ๐Ÿ˜€
I agree with you about flying. The only damage I've sustained flying was a bent front rotor, so I now remove it. Means I do need to carry a BB tool (or borrow one at the other end) but I still prefer that to mucking about with those tiny rotor bolts...
Posted : 21/06/2015 11:32 am
not sure what you mean by know better, I'm taking a guess that it's an actual shimano hub so a valid combination.
Posted : 21/06/2015 1:14 pm
Nothing stopping you using the bigger bb-tool-fit ring on a qr hub, it still fits and works, its just they are comedically overpriced as a spare from shimano and otherwise only come with front 15 or 20mm hubs. also note that you need a deeper cassette tool to clear the locknuts on rear certerlock hubs, i had to buy another one as the (park tools,no less) one i had was too shallow to engage in the lockring.
Posted : 21/06/2015 1:19 pm
