I have a pair of wheels that came with a rear 142x12mm configuration but I can't see how to remove the adaptors and fit 135mm ones. My bulbs were easier as you can see the circlip. Can anyone advise? I've tried diagram searches on Google but no luck yet.
Posted : 11/10/2012 8:55 am
Have you tried the hope tech section. I think it's an exile change required but not sure
Posted : 11/10/2012 8:59 am
Posted : 11/10/2012 9:01 am
IIRC they are just a push fit on the rear.
Hub & axle is the same, just the end caps differ.
Posted : 11/10/2012 9:02 am
I did think push fit but a good wiggle by hand didn't budge it. I'll use a cloth and a gentle bit of molgrip use.
Posted : 11/10/2012 9:17 am
They do require a fair bit of welly to get them off!
Posted : 11/10/2012 9:19 am
You have to take the cassette off to remove the drive side adaptor, but just wiggle and pull off with molegrips ๐
Posted : 11/10/2012 1:13 pm
