I'm after some 4 pot brakes for the alps trip this year - the SLX's can be had for around £160 a pair. Zee's seem to be more expensive. What's the difference, I know SLX are more of a trail brake and Zee's are downhill orientated - but other than that should the braking power be about the same?
I'd say they'd be essentially the same brake with very minor differences. SLX a newer, lighter brake though.
Some alternatives for you:
https://www.bike-components.de/en/Magura/MT5-Carbotecture-Front-and-Rear-Disc-Brake-Set-p45429/
https://www.bike-components.de/en/Shimano/XT-BR-M8100-Disc-Brake-Set-w-G03A-Resin-Pads-J-Kit-p71594/
All Shimano brakes are very very similar, good brake/break down here...
https://forum.cyclinguk.org/viewtopic.php?t=123023
Don't forget there's also the "deore" MT501 which is basically the same again for ~£110/pair, or considerably less if you have some shimano levers you can re-use and just buy the calipers.
