new reverb - will a...
[Closed] new reverb - will a bleed sort this ?
warranty replacement reverb, I fitted it and shortened the hose the other week, kept hose and remote high, didn't lose any fluid, so seemed fine without a bleed. First ride on Sat there, was getting a bit slow. Sunday even slower, even on highest speed. If I wind the speed back from highest it doesn't move at all.
Am thinking a decent bleed will sort, otherwise it's back to the shop it goes I guess.... ?
Posted : 24/04/2017 10:31 am
Transfer.
It's not like you weren't told .....
Yeah, bleed.
Posted : 24/04/2017 10:33 am
scotroutes - Member
Transfer.
Colin - I have a new shiny Transfer, on the Anthem - followed your advice ๐Ÿ™‚
This is the reverb on the Soul, just been replaced under warranty, again....
Posted : 24/04/2017 10:35 am
I'll watch this with interest. I replaced a Reverb recently due to two big scratches put on the old one (my fault entirely). The old one had been faultless for the 4 years I'd had it. The new one is doing similar stuff to Iain's.
Posted : 24/04/2017 10:56 am
Sounds like your hose shortening might not be 100% successful.
A bleed should sort it, but if it's gradually getting worse, then you may have a leak on the hose connection - the tiniest bit of oil leaking is enough to cause your symptoms.
Posted : 24/04/2017 11:09 am
Well, I've bled it and it's working as normal, load of small bubble streams came out so hopefully it's sorted, thanks all.
Posted : 24/04/2017 9:45 pm
