New or Old Rotors?
[Closed] New or Old Rotors?
I'm fitting a new set of brakes to the mighty Krampus this evening, the new ones came with rotors included in the box.
Is there any reason why I should change the rotors too?
Will bedding in be easier/quicker if I use the old rotors?
FWIW, I've already removed the front rotor as I've got a new front wheel and the rotors provided with the brakes are the same size as the old/current ones.
Posted : 24/10/2018 7:35 pm
I wouldn't think there will be much difference in bedding in etc really.
That said, I would probably just fit the new rotors if you have new brakes.... Particularly if a different brand to the original ones.
Posted : 24/10/2018 10:07 pm
If the old ones aren't badly worn, I'd just keep using them.
Posted : 25/10/2018 1:38 am
Thanks for the replies.
I decided to follow both suggestions and have fitted a new rotor to the front and kept the old one on the rear (although I may well change the rear one next time I remove the back wheel)
Posted : 25/10/2018 9:37 am
Keep using them till they die.
Posted : 25/10/2018 10:08 am
Maybe just me, but if I fit new rotors with used pads ( not applicable to you I know) I sometimes end up with brake judder, especially on the front. I'd definitely fit the new discs, keep the old ones as spares in case of damage.
Posted : 25/10/2018 10:28 am
I know this issue with older, "softer" forks. All these new, fat 34 or 36 or so forks don't have this problem any more (I think at least).
Posted : 25/10/2018 12:28 pm
